588,489 active members*
4,250 visitors online*
    Jan 2012
    iscar high feed mill cutter
    I was wondering what is the smallest helix bore you can make with an iscar hi feed mill cutting tool? Most tools I use have a min and max of the helix bore that can be made with a particular tool
    May 2004
    4519
    Maximum helix bore? Are you sure? Minimum should be a the outside cutting diameter plus the inside cutting diameter of the inserts.
  1. high feed rate in VoluMill
    By MPTD in forum Fanuc
    Last Post: 01-17-2012, 01:24 PM
  2. Feed-Max Mill High Performance Slotting Pocketing & Contouring
    By CDTooling in forum News Announcements
    Last Post: 08-29-2010, 08:16 PM
  3. High feed endmill
    By mackie29 in forum Hard / High Speed Machining
    Last Post: 02-28-2010, 01:52 AM
  4. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 11:14 AM
  5. Iscar .375 indexable mill
    By mc_n_g in forum MetalWork Discussion
    Last Post: 08-10-2007, 07:46 PM
