587,758 active members*
2,836 visitors online*
    Sep 2009
    51
    proseries bedmill
    turn your vision into business. :withstupi
    With our proseries bedmill, generate profit from your creativity. By using our top seling MACH3 software, you can renber your tool's paths into G-codes. Then use your G-codes from your model to creat complex shapes made out of wood, plastic, or metalthat that can be machined by our 4" axis capable Proseries bedmill.
    The additional axis allows you to perform complex rotary machining normally done on expensive industrial equipment at a fraction of price.By taking advantage of our combination of accessories you too can sophisticated geometrical designs.
    (wrong)HM-200 CNC MILL
    Specification:
    machine weight:532.97kg
    Footprint:36''*24''
    Shipping weight:625.96kg
    Table size:40''*12''
    Table travel x axis:22''
    Saddle travel y axis:11''
    Head travel z axis:11.5''
    T-slot size:5/8''
    Slot on table,qty. :4
    Spindle :
    Motor hp rating:2hz
    Min. speed:150rpm
    Max. Speed:4000rpm
    Spindle taper: R-8
    Positioning accuracy: + or -0.0005''
    Quill diameter:3.15''
    Axis
    Stepper motor(xyzaxis):1700 in-oz
    Ball screw size(x axis):0.984''
    Ball screw size(y axis):0.984''
    Ball screw size(z axis):0.787''
    Ball screw pitch:0.196''
    Ball screw precision5
    Sep 2007
    8
    Strange use of smilies. :rainfronuts)
    Dec 2009
    27
    Quote Originally Posted by CAF Cues View Post
    ture,maybe he/she just wanted to drew more attention without noticing the meaning of the smiles.but what you posted is meaningless as all knew his/her wrong use of smiles.
    Sep 2009
    51
    Quote Originally Posted by sindychen View Post
    turn your vision into business. :rainfro:
    :cheers:With our proseries bedmill, generate profit from your creativity. By using our top seling MACH3 software, you can renber your tool's paths into G-codes. Then use your G-codes from your model to creat complex shapes made out of wood, plastic, or metalthat that can be machined by our 4" axis capable Proseries bedmill.
    :banana:HM-200 CNC MILL
    Specification:
    Footprint:36''*24''
    T-slot size:5/8''
    Spindle :
    Motor hp rating:2hz
    Min. speed:150rpm
    Max. Speed:4000rpm
    Spindle taper: R-8
    Axis
    welcome to http://www.atron.com.tw
    shype:twhowmau012
    msn:[email protected]
    Sep 2009
    51
    [QUOTE=sindychen;705464]turn your vision into business.
