588,380 active members*
5,328 visitors online*
    56
    DXF export from Corel - Text cutting
    Is this the only way?! I export from corel as DXF V10, import into BobCad, and I have to select these tinyline/arc segments in the middle of each letter to move to layer 1!
    Why are the line/arc segments broken? The font was converted to curves before exporting. This always works with vinyl cutters. A 3 Axis router is only 1 axis more than a vinyl cutter. So what, you're only changing the Z.
    You have to cut the middle first, then cut the outside when cutting completely through. So, any text must be in 2 layers.
    Seems by default "Mach2" always cuts outside first. This will cause the font letter inside to rip out.
    Ideas?
    Jan 2004
    111
    In corel you need to change the order that the objects are in. I use the trace tool and then seperate the seperate objects. After that you can put the objects in the right order for what to cut first. Other then that you may want to try double sided tape or something. I'm interested in how this works out for you, so make sure and update us if it works for you.
    Have a good one.
    Dave
    131
    this was discussed previously, well maybe not exactly but something similar. if you just need text to dxf check out ttf2dxf http://home.carolina.rr.com/gcodemcode/
    hope this helps you out
    56
    OK, sorry about the delay. The way to do this is to convert text to curves. Select the innner parts and move to a new layer. Export out as DXF v10. Import into bobCad and select all then select the optimize feature. Save it. Load the DXF into Mach2, set your layer depts and speeds, generate G-Code and cut.
  1. Replies: 7
    Last Post: 01-18-2012, 03:52 PM
  2. single line fonts?
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 02-18-2006, 06:51 PM
  3. Rhino dxf export
    By Ursine in forum Rhino 3D
    Last Post: 04-25-2005, 04:57 PM
  4. cutting text with a router
    By CNC Darren in forum DIY CNC Router Table Machines
    Last Post: 10-14-2004, 11:04 AM
