Hi
i have a problem with memory check on my partner MB18 with centurion 6 control.
After boot i stop to charge the cnc exe, and with F3 from menu' list i check the memory (on the simdisk)
the result is 760k memory but the report inform me that 404K are in bad sector,so the avaible memory is only 160k.
What it means?
There are some chip memory bad?
The simdisk card have two side,in upper side there are 6 chip and on the board there is write 6mb flash, it is a chip for ram memory?
Anather thing: there is a flat cable that connect the simdisk card with NCB control card, if i want to update my yistem and replace the simdisk card with cf card or equivalent device i need to know the function of this flat cable, where i can conect it ,if i replace the simdisk card?
I think this flat connect the NCB card with ISA bus of MB.
Is true?
many thanks in advance
Alberto
