Hi
Few days ago I started with learning some G code - but really basic one.
I tried to programmed it for the letter ''P'' and I came to this:
N10 #120=500
N20 G0 X75 Y0
N25 G1 X75 Y35 F#120
N30 G1 X89.639
N35 G1 X95.844 Y30.642
N40 G1 X95.844 Y19.356
N45 G1 X90.011 Y16.0
N50 G1 X74.994
So far I belive this is ok. Now I have the task to do something similar but for the letter "N". The problem is because I have several requirements given:
- the code has to be given (?) on the following sketch: HERE
I have absolutelly no idea what is this and how to use this sketch
- commands that can be used are G0, G1 and M30
- depth of process is 0,2mm
- starting point is at the bottom left corner
- area of material Z=0
- process is towards -X (negative) where X is almost whichever number (and not towards +X positive)
- speed of process is 100 mm/min
- dimension of the square aare 50x50 mm
I think I could do the program code for ''N'' letter without any requirements but those requirements (already the first one) confused me a lot.
So if anyone is willing to help to create this G code, I would appreciate it.
Thank you.
