603,316 active members*
2,731 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Takeout Unused G Code commands in Mastercams Generated G Code
Results 1 to 9 of 9
    Mar 2009
    10
    I apologize If there is already a post on this I just found it hard to find with my limited knowledge on the subject.
    -What I have-
    Mastercam X2
    Haas SR-100 Gantry
    -Question-
    I have tried a few of the default Default Routers that might apply to my machine in "Machine Types" menu but after I plot my tool paths and post the G code I get some extra code that errors my machine. I get the command G8 and I don't believe that's defined in my machine. I could be wrong I am very new to this and it's my first machine. If I delete the trouble code out it works fine but I would like to find a solution that will have Mastercam post it correctly the first time. Any ideas?
    -Possible Solutions?-
    1. From what I read it seems like the post-processor is what posts this code but I wasn't able to figure out how to edit it to my machine.
    2. It would seem that all the CNC Router "Machine Type" files are ".RMD" files. Would I be able to download a .RMD file for a Haas Router for free?
    Apr 2003
    3578
    Are you doing drill block drilling or saw cutting on the Router?
    If not I use the default Haas Post from the mill side. I can later change the to a RMD for you.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Mar 2009
    10
    Quote Originally Posted by cadcam View Post
    I'm so new to this i don't know what block drilling or saw cutting is. I did work at a machine shop for a very short time and I would be using the gantry machine much like a mill. I will try posting the code as if it wore a mill and see how it goes. thank you for you input .
    Apr 2003
    3578
    What product of the Mastercam did you buy was it Router, What Machine Def did you use the Default router post or another Machine Def.
    Cadcam
    Jul 2010
    Similar issue
    I have a Bridgeport VMC and I encounter a similar issue with the post code that MasterCam creates. Is there a place I can change the post code to be more specific to my machine type? Any info would help greatly. Thanks.
    Jul 2010
    Similar Issue
    I have MasterCam X2 and I was using the default machine type. I have yet to try the 3-axis VMC, but I wanted to ask someone to see if it will make much of a difference. Thanks.
    Alex
    May 2007
    312
    Use the Haas VMC post, I am not even sure what G8 was used for.
    Jul 2010
    4
    open mastercam X , then choose file , edit/open external
    looking for the post which you are using and edit whatever you want it to be
    Jul 2010
    4
    Edit post of the Mastercam x ..., just open mastercam, then File, edit/open external
    and looking in Drive:\mcamx\mill\post then open the post which you want to edit.
    Now you are free to edit what you want it to be for your machines
  1. Replies: 51
    Last Post: 09-16-2020, 01:28 AM
  2. Help with getting a Mach3 machine to read a code generated in Mastercam x5
    By poolrod2 in forum Uncategorised CAM Discussion
    Last Post: 09-24-2013, 11:39 PM
  3. Why are there F1.0 commands in my code?
    By SWATH in forum Rhinocam
    Last Post: 12-05-2011, 05:40 PM
  4. HDI remove the .5 x,y offset generated in Mach 3 when I upload code?
    By billmiller in forum Mach Software (ArtSoft software)
    Last Post: 08-20-2010, 01:33 AM
  5. Simple G-code commands...
    By WilliamD in forum G-Code Programing
    Last Post: 01-12-2006, 07:27 PM
