588,542 active members*
4,771 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Hypertherm Plasma > HPR400XD - Bevel test cut comes up short
    May 2024
    My test cut comes up short so I can’t proceed cutting the actual parts. Anyone know what to do to fix this issue? Test part is programmed 100mm x 100mm but the outcome is 100x97 mm short on the bevel side (+45 knife bevel). Please help. Thanks!
    Apr 2016
    20
    Quote Originally Posted by Osang View Post
    If your control allows add additional material offset.
    I find keeping long point on top of plate when possible gives more accurate results. Also cutting square sides last.
  1. Bevel on plasma cut parts
    By Bradnicent in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-01-2019, 12:59 PM
  2. Test travel comes up short
    By rcheli in forum LinuxCNC (formerly EMC2)
    Last Post: 03-20-2018, 04:12 PM
  3. Blind Bevel cut
    By 17kennyr in forum Hypertherm Plasma
    Last Post: 01-15-2015, 12:50 PM
  4. No a smooth cut and need to add bevel
    By nambass in forum Vectric
    Last Post: 03-11-2014, 02:12 PM
