588,685 active members*
5,927 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Rapid speed between cuts(plasma)
    Nov 2006
    71
    Hi everyone..I am playing with the evaluation version to be used on the plasma cutting table that I am building..I set up the plasma tool to have a feed rate of 25 ipm..but my table will have a rapid speed of 50 ipm..Looking at the g code generated,it has a cut speed of 25 like it should but there is no change to make it rapid to 50ipm over to the beginning of the next cut..thru out the complete G code it stays at 25 ipm..Did I miss something in the initial setup or does it not have this feature to set rapid speeds..I am using Mach 2 plasma pause for the post processer..Mike
    Nov 2006
    71
    Figured it out...
    N0260 M05 ...this line shuts off the torch
    N0270 G04 P0.25....this makes it pause for .25 of a second
    N0280 G00 Z1.0000..when a G00 is used this makes mach go to its rapid speed set up in the motor tuning
    N0290 X29.2604 Y20.2910..and then this is the point that it rapids to..
    Then a couple of lines after that it resets the feed rate...All right then..thank you anyway..Mike
  1. frustration....plasma cuts off during cuts any ideas?
    By gpnjuice in forum Waterjet General Topics
    Last Post: 11-19-2007, 01:45 AM
  2. rapid speed
    By drafterman in forum DIY CNC Router Table Machines
    Last Post: 11-03-2007, 05:31 PM
  3. rapid speed
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 06-04-2007, 03:23 PM
  4. New plasma cutter ( Even cuts concrete )
    By ynneb in forum Waterjet General Topics
    Last Post: 01-20-2007, 08:54 PM
  5. New Taig, 8 ipm maximum rapid speed?
    By fivaxis in forum Taig Mills / Lathes
    Last Post: 05-11-2006, 02:55 PM
