588,550 active members*
5,203 visitors online*
IndustryArena Forum > Community Club House > 4 axis controller for 3 axis machine?
Results 1 to 9 of 9
Hybrid View
    May 2006
    88
    Hey everyone,
    As some of you may know, my friend's father built a board for my cnc machine but it failed miserably, so I'm looking to just buy one. I am looking at the hobby cnc boards because they're cheap, I know it'll work, and they support low voltage (12v) motors, such as mine.
    Anyways, they're having a sale, and they only have 4 axis cnc controller kits left. I am building a three axis cnc, but would it still work and not cause any problems? I'm probably using Mach3 software.
    Thanks everyone!
    Nov 2005
    83
    Yes it will work. You don't need to use the fourth axis if you don't need it.
    It is better to have it there. If there is a problem with the driver on any of the other axis, you can swap to the spare one and reprogram Mach3 to use it. Also you may decide to add a rotary table at a later time in which case it will come in handy.
    Apr 2005
    3634
    Genguy,
    Good advice.
    May 2006
    88
    Thanks for the advice, guys. I will probably buy the kit tonight. I am not much of a solderer though, has anyone had any experience with these kits? How hard are they to put together?
    Jan 2006
    357
    there are atleast two threads on the zone that I have seen recently, do asearch for them, I think you will find them informative
    May 2006
    88
    Thanks, I tried searching but the search is kinda weak and I can never get much useful stuff out of it.
    Apr 2005
    3634
    Maybe this will help you (search)?
    http://www.cnczone.com/forums/showpo...06&postcount=7
    Jan 2006
    357
    Here you go if found it in less than 20 seconds
    http://www.cnczone.com/forums/showthread.php?t=25504
    May 2006
    88
    Thanks a ton, Guys!
