Hi all,
I was given a piece of something resembling g-code at work and told to decipher it... having never worked with this stuff before, I'm a bit lost. I'm guessing the first couple lines are machine specific, but the syntax for the rest is just slightly different from what's in tutorials online - for instance, what's going on with the out of order and repeated line numbers? Is there a difference between "Dwell" used here and "G04?"
Pasting the first few lines below.. could anyone point me in the right direction?
Thanks in advance!
0000 EZPATH|SX 1 MODE|INCH
0001 TLCHG I10 T10 10
0002 SETCSS G3 C444.00 S2000
0003 RAPID ABS X0.0000 Z5.0000
0004 AUXFUN M8
0005 STARTPATH 1
0006 RAPID ABS X0.0000 Z0.0000
0850 LINE ABS X1.6711 Z0.0000 F0.0100
0851 LINE ABS X1.6711 Z-0.0978 F0.0100
0852 LINE ABS X1.6029 Z-0.0978 F0.0100
0878 LINE ABS X1.6229 Z-0.0978 F0.0010
0879 LINE ABS X1.6029 Z-0.0978 F0.0100
0880 LINE ABS X1.6129 Z-0.0978 F0.0100
5881 LINE ABS X1.6429 Z-0.0978 F0.0010
0882 LINE ABS X1.6029 Z-0.0978 F0.0100
0883 LINE ABS X1.6329 Z-0.0978 F0.0100
0884 LINE ABS X1.6629 Z-0.0978 F0.0010
0085 LINE ABS X1.6029 Z-0.0978 F0.0100
0886 LINE ABS X1.6529 Z-0.0978 F0.0100
0887 LINE ABS X1.6829 Z-0.0978 F0.0010
0888 LINE ABS X1.6029 Z-0.0978 F0.0100
0889 LINE ABS X1.6729 Z-0.0978 F0.0100
0890 LINE ABS X1.7029 Z-0.0978 F0.0010
0891 LINE ABS X1.6029 Z-0.0978 F0.0100
0892 LINE ABS X1.6929 Z-0.0978 F0.0100
0893 LINE ABS X1.7229 Z-0.0978 F0.0010
0894 LINE ABS X1.6029 Z-0.0978 F0.0100
0895 LINE ABS X1.7129 Z-0.0978 F0.0100
0896 LINE ABS X1.7429 Z-0.0978 F0.0010
0897 LINE ABS X1.6029 Z-0.0978 F0.0100
0898 LINE ABS X1.7329 Z-0.0978 F0.0100
0899 LINE ABS X1.7629 Z-0.0978 F0.0010
0900 LINE ABS X1.6029 Z-0.0978 F0.0100
0901 LINE ABS X1.7529 Z-0.0978 F0.0100
0902 LINE ABS X1.7787 Z-0.0978 F0.0010
0903 DWELL S1.0000
0040 LINE ABS X1.6029 Z-0.0978 F0.0100
0000 LINE ABS X1.6029 Z-0.0978 F0.0100
0001 LINE ABS X1.6029 Z-0.1955 F0.0100
0902 LINE ABS X1.5387 Z-0.1955 F0.0100
0928 LINE ABS X1.5587 Z-0.1955 F0.0010
0929 LINE ABS X1.5387 Z-0.1955 F0.0100
0930 LINE ABS X1.5487 Z-0.1955 F0.0100
0931 LINE ABS X1.5787 Z-0.1955 F0.0010
0932 LINE ABS X1.5387 Z-0.1955 F0.0100
0933 LINE ABS X1.5687 Z-0.1955 F0.0100
0934 LINE ABS X1.5987 Z-0.1955 F0.0010
0935 LINE ABS X1.5387 Z-0.1955 F0.0100
0936 LINE ABS X1.5887 Z-0.1955 F0.0100
0937 LINE ABS X1.6187 Z-0.1955 F0.0010
0938 LINE ABS X1.5387 Z-0.1955 F0.0100
0939 LINE ABS X1.6087 Z-0.1955 F0.0100
0940 LINE ABS X1.6387 Z-0.1955 F0.0010
0941 LINE ABS X1.5387 Z-0.1955 F0.0100
0942 LINE ABS X1.6287 Z-0.1955 F0.0100
0943 LINE ABS X1.6587 Z-0.1955 F0.0010
0944 LINE ABS X1.5387 Z-0.1955 F0.0100
0405 LINE ABS X1.6487 Z-0.1955 F0.0100
0946 LINE ABS X1.6787 Z-0.1955 F0.0010
0470 LINE ABS X1.5387 Z-0.1955 F0.0100
0480 LINE ABS X1.6687 Z-0.1955 F0.0100
0490 LINE ABS X1.6987 Z-0.1955 F0.0010
0500 LINE ABS X1.5387 Z-0.1955 F0.0100
0051 LINE ABS X1.6887 Z-0.1955 F0.0100
0952 LINE ABS X1.7125 Z-0.1955 F0.0010
0953 DWELL S1.0000
0954 LINE ABS X1.5387 Z-0.1955 F0.0100
0950 LINE ABS X1.5387 Z-0.1955 F0.0100
0591 LINE ABS X1.5387 Z-0.2933 F0.0100
0592 LINE ABS X1.4787 Z-0.2933 F0.0100
0598 LINE ABS X1.4987 Z-0.2933 F0.0010
... etc.
