603,400 active members*
2,668 visitors online*
Thread: syntax error
Results 1 to 10 of 10
    Dec 2004
    132
    syntax error
    I have a syntax error on my program. I had several people check it and seemed to have no problems I even compared it with other peoples programs that worked. Is there any hidden errors that I could check for?
    please help
    Jul 2003
    15
    make sure all letters are uppercase and zeros really are zeros and not O's and ones are ones and not I's or L's
    I would be happy to run it by cncsimulator on my system see what it finds ... of course I would need the .nc file
    Dec 2004
    132
    how do I do that?
    Jul 2003
    15
    just attach the file as a .txt file instead of an .nc file rename it and post it along w/ a response
    Dec 2004
    132
    file thanks man
    Attached Files Attached Files
    Jul 2003
    15
    I wish I could be of more help. You will notice in the simulation.png I modified your file somewhat. I don't know what the T202 in line N10 did or does but w/ it the output was completely useless at least as far as I could run it. I believe where the color goes from blue to pink the simulation is saying you are out of spec for the hardware(?). Let me know if any of this makes any sense to you. Maybe I can understand more. I am just now starting CNC Programming in college even though I am 33 years old. Again, please let me know if you understand any of the output.
    Jan 2005
    304
    Try This
    See the changes below marked with (*****)
    cogsman1
    :6001
    N05X2.5Z1.0T0
    N10T202G96S500M3
    N15G0X1.1Z0
    N20G1X-.02F.002
    N25G0X1.1Z.05
    N30G73U.025R.025
    N35G73P40Q85U.01W.005F.005
    N40G0X.100(******)
    N45G1G42Z0(*****)
    N50G1X.25C.05
    N55Z-.250
    N60X.500A135
    N65Z.-750
    N70X.750R.100
    N75Z-1.500
    N80X1.0A120C.050
    N84X1.05Z-1.7(******)
    N85G0X1.1Z.05G40(******)
    N90G70P40Q85F.002(*****)
    N95G00X2.5Z1T00
    N100M30
    Jul 2003
    15
    no matter what I try I personally can't make sense of the code
    Jun 2004
    450
    What control is this posted for? And what line do you get the error on?
    Jul 2004
    3
    Post
    N05x2.5z1.0t0 ??? T0200 T0 Not Existe
    N10t202g96s500m3
    N15g0x1.1z0
    N20g1x-.02f.002
    N25g0x1.1z.05
    N30g73u.025r.025
    N35g73p40q85u.01w.005f.005
    N40g1 G42 X.100 No Comp. G42
    N45g1z0
    N50g1x.25c.05
    N55z-.250
    N60x.500a135
    N65z.-750
    N70x.750r.100
    N75z-1.500
    N80x1.0a120c.050
    N85g0x1.05z-1.7g40
    N90g72p40q85f.002
    N95g00x2.5z1t00 T0200
    N100m30
  1. Bad Contour Error while Pocketing
    By sundara in forum BobCad-Cam
    Last Post: 05-29-2005, 12:10 PM
  2. 6030 Error 17 problem
    By BigLou in forum Fadal
    Last Post: 01-31-2005, 09:42 PM
  3. Boss 8 Error 4000
    By masspfei in forum Bridgeport / Hardinge Mills
    Last Post: 01-26-2005, 01:32 AM
  4. Fadal error codes
    By HareBall in forum Fadal
    Last Post: 01-22-2005, 02:52 PM
  5. Need help on Hitachi Seiki error 1012
    By anti-SAMS in forum DNC Problems and Solutions
    Last Post: 11-25-2004, 02:26 AM
