587,917 active members*
3,353 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Harrison Alpha 400 Spindle Fault Detected - Error Code 2
    Nov 2023
    4
    Hello,
    I'm using a Harrison Alpha 400 lathe and it's flashing Spindle Fault Detected on the DRO and the error code 2 in the cabinet. Shutting it down used to clear the fault but it no longer does. I've seen on other threads here that an error code of 9 pertains to the chuck guard switch but I couldn't find what 2 means and fiddling with the switch hasn't helped. I think has it a Mitsubishi A200 inverter if that helps. Can anyone offer any insight?
    Thanks in advance.
    Nov 2023
    4
    Re: Harrison Alpha 400 Spindle Fault Detected - Error Code 2
    If anyone has the same problem if did turn out to be a faulty chuck guard switch.
    Aug 2010
    Photo of the alarm from the Alpha 400 manual
  1. Replies: 14
    Last Post: 05-05-2023, 10:24 PM
  2. harrison alpha 400
    By tommy san in forum Australia, New Zealand Club House
    Last Post: 11-15-2010, 08:01 PM
  3. Harrison Alpha 400 HELP!!!!!
    By themachinest in forum Community Club House
    Last Post: 02-26-2009, 05:44 PM
