588,399 active members*
5,546 visitors online*
Results 1 to 6 of 6
    Sep 2003
    1113
    WHATS THIS?? - Optical Switch??
    Hey gang - ben dumpster diving and have been rippin into a heap of printers and 5.25 floppy drives . A lot of interesting components - but sometimes I feel like the native staring at the Coke bottle that fell from the sky in the middle of the desert!
    So WHAZZISS? # wires out. (No colors) 2 sides - and a slot the wiper or flipper slides through. Im'm sure its a switch no doubt but where do I hook up the wires? ANy clues - Note I have no shame about my ignorant questions....
    heres a pickie (I hope) TIA - Jim Hey that worked! Now if I could just get the tumbnails - no worries...
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    24220
    It looks like an opto switch the K side is common to the cathode of the light source and the emitter of the reciever transistor. the anode should be fed through a resistor to the + supply, depending on what voltage you run at and the C collector should have a resistive load to the + supply, with the output taken from the collector, I can give you an example make/type if you need it.
    Al
    Albert E.
    Feb 2004
    2337
    It may be easier to identify if you post a picture of the item also. Not just the schematic
    Being outside the square !!!
    Sep 2003
    1113
    Al-the-Man
    Say thanks for that! The one I'm looking at is ID'd as: HCS-4094V-O. Came out of a floppy - 5.25 in. No luck on Google. Any pointers you got would be helpful I'm sure.
    Ynneb - I'll dust of the camera an post in a few.
    These seem to be used a lot for 'paper out" on printers and limits in floppy drives - Should be usefull enuf for other bits of work - just keep 'em free of crud. Now I just need to sort out the wiring and resistors/voltages/etc!
    Jim
    24220
    Jim, I found a listing under obsolete semi's but no spec's, connect the common cathode/emitter to 5v common, connect a 500ohm resistor from anode to 5v+ and a 500 ohm res to the (C)ollector and put a meter between common and collector and pass something through the slot and you should hopefully see it switch between 0 and ~5v. Some of these slotted opto switches are darlington out but you should see some results.
    Al
    Albert E.
    Sep 2003
    1113
    Great Al-the -Man!
    I'll shag on down to the radio SNack tommorrow and give it a check out.
    Thanks! Jim
  1. Optical interupt switch implementation.
    By owhite in forum CNC Machine Related Electronics
    Last Post: 07-26-2009, 10:27 PM
  2. limit switch override
    By swarfmacdaddy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-12-2004, 10:47 AM
  3. Optical Switch w/Interrupt mechanism
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 11-10-2004, 03:51 PM
  4. optical switch
    By natchez in forum Xylotex
    Last Post: 05-01-2004, 01:45 PM
  5. Optical Limits
    By IndHobby in forum News Announcements
    Last Post: 02-10-2004, 07:51 AM
