588,232 active members*
4,227 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > New to bobcad v22 help opening file?
Page 1 of 2 12
Results 1 to 20 of 37
    Feb 2009
    13
    Question New to bobcad v22 help opening file?
    Hey guys I am new to bobcad and cam programming I have solidworks 2008 and have saved my part as an XT file and every time I open it in bobcad v22 I get an error and bobcad shuts down? I do have the latest build of v22 what do I do?
    Dec 2008
    4548
    ".sldprt" is BobCads Solidworks importer. Not familiar with solidworks so dont know what an XT file is. Maybe someone else?
    Bueller.....Bueller?
    Feb 2009
    13
    Question
    Quote Originally Posted by BurrMan View Post
    Ok I just exported it as an iges file and was able to open it up now having trouble with tool paths alot of inside pockest with holes 4th axis out or round stock but I am just indexing this part my problem is getting a tool path that will work it needs to go from the end of the part and finish this part in 1/2" at a time in full because it sticks out of the 4th 5 inches I am useing a 1/2" cutter the stock is 2" round the part is 3/4" tall but the first milling is 1.25 from top of stock it is an offset part kind of like a z____ shape. When I run the tool path the entire system shuts down?
    Jan 2006
    4396
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Mar 2005
    368
    Quote Originally Posted by Coolster View Post
    I have the best luck with .sat files from SW into v22. Large files load quickly.
    Don't know about v23.
    Good luck,
    moldmker
    Dec 2008
    4548
    Quote Originally Posted by moldmker View Post
    Good luck,
    moldmker
    Doesnt V22 import solidworks files???
    For Coolster, can you post a file to help explain? It's kindof hard from a forum description.
    Burr
    Feb 2009
    13
    Burr
    Had no problem opening an iges file but everyother time I try a new tool path it shuts down? The entire software shuts down? I am calling bobcad today I have to get this working it is going to put me in a crunch if i dont get this part running within a few days. I will try to post the file tionight.
    Mar 2005
    368
    Doesnt V22 import solidworks files???.....
    Yes, but if the model is complicated it takes a long time to load. Some I've aborted after 30 mins.
    Convert it to .sat and it loads in 5 secs.
    (my observation on my system, never confirmed on other systems)
    Also, SW has different Configurations that can be applied to it's model. This is an engineering tool that allows a model to be configured in different states, such as: with or without holes (or just a certain hole), castings "as cast" and "as machined", sheetmetal parts "as bent" and "flat pattern", etc.
    When you import a .sldprt into BC there's no opportunity to select which Configuration you want, so you get them all combined in one model.
    Save it as a dumb solid (.sat, .igs, .stp) and it saves as the current config.
    I got burnt once by a hole pattern mix-up, I don't chance it anymore.
    If you're getting SW models from customers without prints, you may want to get SW's free viewer called eDrawings so you can verify model configurations.
    moldmker
    Feb 2009
    13
    Question
    moldmker
    I own solidworks 2008 my work keeps me on it. I have saved it as an ides file and bobcad opened it up fine it looked fine I did some tool paths but 90% of the time bobcad will shut down or freeze with no responce when I try to make a tool path?
    Mar 2005
    368
    Can you post a sample .igs file for us to look at?
    Make sure it's one that gives your system trouble, then we can isolate whether it's the file or your system.
    I use SW 2007 into v22 with minimal problems.
    moldmker
    Dec 2008
    4548
    OIC,
    Thanks for taking the time to edu me!
    Burr
    Would like to see if the file crashes my computer.
    Feb 2009
    13
    Question
    OIC,
    Burr
    The file is to big to upload. 1.45 MB (1,530,940 bytes) The computer is not crashing the software is I am on a computer that can handle it with not even a thought.
    Dec 2008
    4548
    Try zip the file. Right click it and choose "send to" compressed zip archive. See if it fits then.
    Thats what I meant, to see if it crashes my BobCad, not that I may have a better computer than you. That can start to narrow it down.
    Burr
    Feb 2009
    13
    Question
    Burr
    Ok here try this one.
    Attached Files Attached Files
    Mar 2008
    163
    well I was able to do a 3D path...did you look at your task manger and it said....Bobcad not responding...it will always say that...if you look at the process page you can see the CPU is working...unles you get a message that says Bobcad has encounter a promblem and needs to close...then wait untill the CPU is done doing it's thing...sometime it takes a few minutes...I think it took like 5 to process this jpeg on my system...I did stitch model together to genorate code...I should add the fact that I did this in V23 not V22
    Mar 2005
    368
    Here's a simple v22 path. Seems OK.
    There are 2 untrimmed fillets at one end of the part.
    Sometimes, other file formats work better.
    moldmker
    Dec 2008
    4548
    Darn that Mike is quick! Although I just selected make one solid on import and didnt have to stitch it!
    It opened for mre also Coolster (V22), so I would start to look at your system first.
    Mostley, make syure you have the latest drivers for your vid card. Do you have an NVidia perhaps? 7800 or something like that?
    Mar 2008
    163
    I'm not called Two Pump Mike for no reason...
    Jun 2007
    65
    .IGS files always has something missing I always try and use .STP files.
    John
    Feb 2009
    13
    Question
    Quote Originally Posted by COMMAND JOHN View Post
    John
    I will try again tomorrow. But yeah it was the Bobcad has encounter a promblem and needs to close thing. I will try updates on everything.
    Just tried to update video card it is up to date. so it is not that.
Page 1 of 2 12
  1. opening a mastercam x file on v9
    By drewmeister in forum Mastercam
    Last Post: 12-16-2008, 12:54 AM
  2. Opening CDR file extension.
    By terry32506 in forum Uncategorised CAM Discussion
    Last Post: 03-02-2008, 05:53 PM
  3. Opening ProE (prt) File
    By allennella in forum Mastercam
    Last Post: 10-11-2007, 02:19 AM
  4. Opening dxf in bobcad
    By bhkelly in forum BobCad-Cam
    Last Post: 02-22-2007, 02:09 PM
  5. Opening Mastercam In Bobcad
    By lakeside in forum BobCad-Cam
    Last Post: 05-02-2006, 04:38 PM
