Hey guys Im working on a 4 foot long HRS Shaft right now that needs to be threaded on one end with an M36 X 4.0 Thread thats around 380 MM long ~15 Inches. Im using a Kennametal Top Notch Threading Insert, Carbide Grade K68 Uncoated. I seem to be having probems making the cutter last, it just doesn't hold up. Current Feed is obviously 4.0 and Speed is at 175, seems a bit fast, but as it is it takes me nearly an hour and a half to cut the thing, and Im barely making shop rate at this speed. Or does this thread just take that long to make? Its somewhere around 50 passes gradually taking a smaller cut as I get deeper into the thread, obviously. Any help with Speed or possibly using different inserts? Thanks a lot Guys, I appreciate the help ahead of time.
