588,195 active members*
5,010 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill > When I click Feed Hold, then move Z, then Cycle Start - does not resume properly...
    Nov 2012
    Here's my issue.
    If I'm machining a part, then click on Feed Hold, then move the Z up manually - say to clear the bit or change the bit (not touching X or Y) - then click on Cycle Start I expect the machine to move back to the appropriate Z height, then carry on. Instead, it moves the X AND Y AND Z axis' and carries on. Any idea what could be causing this?
    Rich
    It looks like that's just the way Mach3 works.
    Try using Stop after feedhold, then use "Run From Here". That should do what you want.
    Nov 2012
    Smile
    Upgrading from 3.043.022 to 3.043.066 fixed this issue. It was added in a release in January apparently. It pops up a dialog warning that it is going to move, then returns to the right spot, then you click Cycle Start again, and the job continues.
    I'll have to check, but I thought I was testing with .066, and got the same results you did??
  1. JSM-40 laser won't move properly
    By Snarkhunter in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-29-2012, 02:57 AM
  2. RIGHT CLICK==> move to layer
    By NCexplorer in forum UG NX
    Last Post: 03-04-2011, 12:55 PM
  3. Start/Resume button
    By ccemc2 in forum LinuxCNC (formerly EMC2)
    Last Post: 11-22-2010, 05:22 AM
  4. Pendant for cycle start, feed hold and estop?
    By Alex_Cole in forum Mach Software (ArtSoft software)
    Last Post: 11-08-2007, 01:10 AM
  5. Axis move during feed hold
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-12-2006, 04:12 PM
