588,030 active members*
4,225 visitors online*
Results 1 to 9 of 9
    Apr 2006
    1016
    ATC automatic tool changer
    looking for commerical spindles, 1 phase 220v to but used with collet chucks for DIY atc... what is the standard collet chuck used in wood working industry? iso 30 or mk2/mk3 chucks
    You can't convert a regular spindle to an ATC spindle that will hols ISO 30 toolholders.
    Apr 2006
    1016
    thats the had the impression i had... could not find a economical
    spindle manufactures that did?.. anyone have any links or leads?
    In the cnc woodworking industry what is the most common chuck type that is used iso30? for the wood working and light metal/ aluminum cnc industry.
    assuming there using some type of atc?
    Apr 2005
    3634
    Free DXF - vectorink.com
    Quote Originally Posted by eloid View Post
    Probably either iso30 or HSK style. depends on spindle HP and manufacturer.
    Keep in mind that an iso30 toolholder with nut and ER32 collet will be close to $200 each, not including the bit. So a set of 5 tools for a toolchanger can easily cost $1200-$1500.
    Apr 2006
    1016
    im planing to have my bubby who's a machinist to do all of the diy
    machining for the toolholder and the tool changer. It will be a simple tool rack setup, the z axis with engage with....tool holders....
    Apr 2006
    1016
    spindle manufactures in offshore?
    any know of any other ,anufactures for spindle that offer atc spindles?
    Jun 2004
    20
    bargain tool holders
    FYI. You can save a good bit of money if you get tool holders from mari tool. I have at least a dozen of them and I am very happy with them so far. Albeit, I have nothing to compare them to since these are the first set of toolholders I've ever had, and I bought based on lowest price. But they seem to be of good quality. $100 for a tool holder, $14 for an er collet.
    http://www.maritool.com/Tool-Holders...duct_info.html
    Jun 2007
    394
  1. X2 automatic tool changer
    By X2cnc in forum Benchtop Machines
    Last Post: 07-27-2008, 12:11 PM
  2. Automatic Tool Changer
    By Rockwall in forum Tormach Personal CNC Mill
    Last Post: 04-21-2008, 11:34 PM
  3. I wish I had an Automatic Tool Changer...
    By Chris64 in forum Uncategorised MetalWorking Machines
    Last Post: 09-10-2007, 01:59 AM
  4. Automatic Tool Changer
    By spalm in forum DIY CNC Router Table Machines
    Last Post: 07-11-2007, 01:49 AM
  5. R8 automatic tool changer
    By N4NV in forum Bridgeport / Hardinge Mills
    Last Post: 03-06-2007, 03:44 AM
