588,638 active members*
5,278 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Table Display screen acting wierd?
    Nov 2013
    402
    Why is the Table Display (little black screen with red toolpaths) working on my Comprehensive Run Page, but NOT working on my Simple Run page?
    On the Comp Run page, it's showing all movements, and toolpaths.
    When I switch to Simple Run page, the screen is just black with the pink/purple crosshairs doing nothing.
    Apr 2013
    28
    Re: Table Display screen acting wierd?
    Have you tried the "Regenerate Toolpath" button?
    Jan 2012
    714
    Click regenerate toolpath button located below and left side of the screen.
    Mine does this quite often.
    mike sr
    Nov 2013
    402
    I tried the 'Regenerate Toolpath' button during the program run, and nothing happened.
    HOWEVER.....
    When the program finished, and reset (M30), I tried 'Regenerate Toolpath' again, and VIOLA! it worked!
    I guess the program needs to be reset and waiting when the button is pressed.
    Learn something new everyday.
    Apr 2013
    28
    More often than not when I load a program the table display window you are speaking of does not display the tool paths when the file is first loaded so I always hit the Regenerate Toolpath button before machining just as a matter of routine.
  1. screen display readout
    By nigel2000 in forum Fanuc
    Last Post: 06-28-2013, 09:49 PM
  2. How to get G154 P1 to display on screen
    By Kool Parts in forum Haas Mills
    Last Post: 10-27-2011, 05:17 PM
  3. System Screen does not display
    By hutch07 in forum Fanuc
    Last Post: 01-29-2011, 06:12 PM
  4. mach3 display screen
    By woodman08 in forum Mach Mill
    Last Post: 08-18-2009, 05:45 PM
  5. Table display screen reversed?
    By bcnc in forum Mach Mill
    Last Post: 06-17-2007, 05:48 AM
