603,945 active members*
4,211 visitors online*
    Oct 2006
    36
    Table display screen reversed?
    The table layout screen in the upper right corner of mach3 screen, everything is reversed. If my part I want to cut is in the upper left of the table layout,it will actually cut the part in lower right on my table. Don't think this is normal ,is there a way to reverse this? The cursor crosshair is also reversed. I tried to do it with my machine settings but did not work. Thanks Brian
    May 2007
    4
    Did you find a solution
    I was wondering if you found a solution to the reversed image.
    Mar 2003
    35494
    Sounds like one or more axis are moving in the wrong direction.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Homemade Screen Printer/Silk Screen
    By Sbthomas13 in forum Machine Created Art
    Last Post: 02-14-2009, 01:35 AM
  2. Y axis reversed
    By Legion99999 in forum Syil Products
    Last Post: 03-04-2007, 06:43 AM
  3. Don't hurt the noob ... 1 axis reversed, help
    By oddatwl in forum Xylotex
    Last Post: 02-14-2007, 07:35 AM
  4. Set the counter display
    By hien100881 in forum Fanuc
    Last Post: 09-22-2006, 05:26 AM
