Hello, Gentlemen, I have a CNC milling machine HAMAI 3VS controlled FANUC 0-M. With her little problem namely the maximum rapid traverse rate (RAPID 100%) of the Z axis crashes mistake OVER TRAVEL and the machine goes to the limit stop. To re zbazować Z axis must change the values in the two parameters and perform a ,, procedure. "In the absence of the possibility of a max speed of travel have losses during production. Has anyone realizes or should be the Z-axis encoder or rather not here to look for the problem?
