588,550 active members*
5,037 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Series 1 - Hole diameter variations
Results 1 to 9 of 9
    I have a Bridgeport Series 1 2HP mill running Mach3 as a replacement to the old Anilam Crusader. The functionality is unbelievable, and so far the mill has been running Monday to Friday on various jobs. However I've a newly discovered issue:
    On spiral drilling or pocketing out a 25mm deep hole (in mild steel) to say 28mm diameter. The bottom half of the hole is out by about 0.30 to 0.40mm, essentially giving me a tapered hole. I'm trying to figure out if this a software or mechanical issue. So far I'm leaning towards the latter. Could the quill bushes be worn inside the headstock? The quill in total is having to extend 50mm down as I have a 25mm clearance due to fixtures. Maximum Z travel distance between limit switches is about 3-4", so 50mm shouldn't be asking to much. Either way, could the increased leverage on the quill at depth cause this issue?
    If so how can I go about fixing it?
    Is there anything else I should check?
    Dec 2013
    5722
    Re: Bridgeport Series 1 - Hole diameter variations
    That sounds mechanical. Is the head in tram? Out of tram might cause that, maybe.
    I guess you could extend the quill and see if it deflects relative to the rest of the head.
    Jun 2005
    1733
    Agree this sounds like a TRAM issue. Check it using a precision square and a long straight drill bit or endmill.
    Russ
    Ok thanks for the replies.
    I think the tram is out, so I'll have to readjust it tomorrow. Found a good tutorial on Youtube!
    However, I'm not fully convinced tramming is the cause. The fact the holes have a larger diameter entry side than exit side makes me think there is excessive play in the quill.
    I'll try your recommendation Jim and post back with the results.
    Apr 2016
    74
    spiral drilling? do you mean boring? the only times i have had that issue it has been tooling or feeds and speeds.
    I have also heard boring called offset reaming. lol
    Quote Originally Posted by JMORLAN View Post
    Either way, it doesn't matter what it's called in this instance. I've tried numerous speeds, feeds, depth per revolutions etc using Gwizard as guidance. All holes bored had the same issue.
    Apr 2015
    170
    Easiest test to make is to put a clock on the end of the tool and put some hand pressure on it and see how much movement you have, maybe there is some wear in the quill but that can usually be negated by gently clamping it. It is surprising just how much twist you can get in the overarm if it is extended, try bringing the workpeice closer to the pillar. If all else fails do a light finishing cut to minimize deflection.
    Dec 2013
    5722
    Quote Originally Posted by jim_cliff11 View Post
    I'm not convinced either, but can't hurt to check it. Are you making a couple of finishing passes in the bottom of the hole? I find that's helpful with a lot of stickout.
    Dec 2013
    5722
    No, spiral drilling (or maybe pocketing). The path of the endmill is a helix as it creates the hole, then normally will make a full circle final pass to flatten the bottom.
  1. Replies: 2
    Last Post: 06-13-2016, 04:38 AM
  2. Replies: 0
    Last Post: 01-05-2016, 01:43 PM
  3. Long Boring .600 diameter hole
    By avarouxis in forum Material Machining Solutions
    Last Post: 10-31-2013, 07:11 PM
  4. Multiple diameter step drilled hole.
    By frogier in forum MetalWork Discussion
    Last Post: 03-28-2012, 08:21 PM
  5. advise reaming A2 .250 deep hole .432 diameter
    By Hiredgun in forum Uncategorised MetalWorking Machines
    Last Post: 12-21-2011, 03:29 AM
