588,672 active members*
6,281 visitors online*
Results 1 to 7 of 7
    Aug 2008
    400
    Exclamation Torus PRO stocked
    Dear Novakon Customers,
    We have a couple of Torus PRO mills in stock available for immediate sale. The bed mills we presently have are one stepper and one servo axis drive. Included is the 6K RPM AC spindle motor with C-300 VFD. Take advantage of the available stock. Processing time is 2-3 weeks upon order.
    The next shipment of Torus PRO’s will be delivered to our facility approximately December 30, 2012, and we anticipate they will be available for customer shipment late January.
    Please E-mail [email protected] with your inquiry.
    Please reference: Torus PRO
    Regards,
    Novakon Team
    Jun 2008
    1082
    I hope this means mine has either shipped or will be shipped Monday! I'm really champing at the bit here.
    Jul 2007
    675
    I know how you feel, but it is well worth the wait. Anyway, it will give you time to design all of your upgrades. Here's mine: PDB, chip enclosure, user interface mount.
    Sent from my DROID2 using Tapatalk 2
    Aug 2008
    400
    PRO Shipping
    Quote Originally Posted by Hirudin View Post
    Hello Hirudin,
    We have tested your machine fully and it is working very well. We are the only ones who build controllers, integrate them and test the completed machine in a shop environment. It does take more time, but the machine will be well worth it. These servo motors and drivers are the only way to go.
    Your machine will be packed and processed for shipping early this week.
    Regards,
    Novakon Team
    Jun 2008
    1082
    Yay!
    Jun 2010
    13
    Quote Originally Posted by Novakon View Post
    ... These servo motors and drivers are the only way to go. ...
    Novakon Team
    Are you planning to put a servo motor in the 8" rotary table, and driver in the controller, for the TPse (Torus Pro servo edition)?
    Are there any future plans for a 5th axis? Or special order?
    +1 :banana::cheers::cheers::banana:
    Aug 2008
    400
    Servos for additional axes
    We have considered the servo for the 4th axis, but at this time the mounting of the motor for the table would have to be changed to accommodate the servo motor. The mount for a servo can be downgraded to fit a stepper motor, but not the other way. Most likely, in the future, we will have the tables made with the motor mount designed for a servo so that that a stepper can be added using an adapter ring fitting the stepper motor. Then it can be used both ways.
    The servo driver will fit inside of the cabinet and can be done almost any time. The addition of the 5th and 6th axis would require an additional parallel PC port and a BOB. Things get real tight putting these extra drivers inside the electrical cabinet. At this time, we have not considered this, due to the low requests for this in the past.
    Because the servo drivers are nicely designed and only need 220 VAC and a few control signals...it would lend itself to fit inside an auxiliary external box and connect up very nicely.
    Thanks for the input. This will be taken under advisement when we look at our customer's needs for future changes.
    Regards,
    Novakon Team
  1. Shipping crate for the Torus PRO
    By Novakon in forum Novakon
    Last Post: 10-29-2012, 01:39 PM
  2. Torus PRO in stock
    Last Post: 10-12-2012, 12:35 AM
  3. Anybody bought a Torus?
    By JohnToner in forum Novakon
    Last Post: 07-28-2012, 11:38 PM
  4. Torus Pro Servo Kit
    Last Post: 07-19-2012, 08:58 PM
  5. Introducing the new Torus CNC Mill
    Last Post: 04-24-2012, 02:43 PM
