588,542 active members*
4,687 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Torus Pro Servo motor acceleration values
    Apr 2009
    123
    Folks,
    What do you guys have in your Mach3 settings for motor tuning/acceleration values for servo edition. Mine came with 14 in/s and it seemed to be too slow for short distance travels as rapids never get achieved. Bumping over 30 makes a bit of a jolt when the table moves and I am also concerned about the preloaded bearings. So what would you say optimum value is?
    Feb 2006
    7063
    Unless you're doing a lot of high-speed 3D profiling, there's little to be gained by trying to set uber-high rapid speeds or acceleration values, other than bragging rights. I run my machines at 250 IPM rapids, and 25 in/sec2 acceleration, which seems about the point of diminishing returns. Faster rapids gain you virtually nothing in terms of reduced machining time, and higher acceleration introduces a LOT more vibration on direction changes, starts and stops.
    Regards,
    Ray L.
  1. Torus PRO servo in action with PDB
    By Novakon in forum Novakon
    Last Post: 09-18-2013, 03:00 AM
  2. Another Torus PRO Servo Edition
    By iGAK in forum Novakon
    Last Post: 03-29-2013, 02:22 PM
  3. Torus Pro Servo Kit
    Last Post: 07-19-2012, 08:58 PM
  4. What values are the velocity and acceleration in Trajectory planner?
    By volkl_ac3 in forum CNC Machine Related Electronics
    Last Post: 06-27-2012, 02:24 PM
  5. Which values are important when choosing the right servo motor?
    By Zeta-Phoenix in forum Servo Motors / Drives
    Last Post: 10-08-2009, 08:51 PM
