587,784 active members*
2,732 visitors online*
    Aug 2005
    578
    Tool changer questions.
    2000 mini.
    toolchanger will only index in one direction. not both
    What is the problem.
    No I'm not calling the repair guy.
    If I can't fix it cheaply, it's out of here.
    Nov 2003
    236
    Call the factory
    Quote Originally Posted by PBMW View Post
    2000 mini.
    If you are on the cheap call the factory and they should be able to help.
    If you do not get outstanding customer service please call me Wayne Reilly @ 805-278-8560
    Mar 2008
    95
    On larger haas machines there are 4 relays in the middle of the i/o board. these control shuttle in and out and rotation try swapping the relays around and see if the problem moves with the relay. All 4 relays are identical no need to worry about coil voltage. I am assuming it is the same for a mini mill.
    Aug 2005
    578
    I'll give that a shot
    Aug 2005
    578
    Looked in my maint manual.
    K11 adn K12 are the CW and CCW relays.
    I don't recall which one didn't work awhile ago. Now it works both dirrections. I had reseated them both.
    I'm thinking a weak relay. Bought 4 of them for about $7.00 apiece from a place in NJ.
    Be here Tuesday.
    Machine runs now so I don't know if the relay was warm and didn't want to play or if reseating it cured it. But it's running.
    Thanks all.
  1. Hoss 16 Tool Automatic Tool Changer
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-03-2011, 10:29 PM
  2. tool changer
    By machinist guy in forum Uncategorised MetalWorking Machines
    Last Post: 07-14-2008, 10:03 PM
  3. Tool changer
    By Sprew in forum Fadal
    Last Post: 04-26-2008, 05:29 AM
  4. Tool Changer picks up wrong Tool?
    By KJ45 in forum Uncategorised MetalWorking Machines
    Last Post: 03-13-2008, 12:51 PM
  5. VM16 Tool Changer Questions
    By Radius in forum Milltronics
    Last Post: 11-29-2007, 05:16 AM
