Hi everybody. I posted another thread, asking for a settings chart for a milling machine. Somebody posted one, and it is so helpfull!!! I was hoping that I could get this same type of chart, but for a metal lathe. Thank you.
There is ALWAYS "Machineries Handbook".
What kind of lathe and tooling are you using?
Machinery's Handbook should suffice for manual lathes using HSS tooling.
For high powered lathes, especially CNC, feeds and speeds are determined by the carbide insert used... both the mfg's specs and trial and error.
Appropriate surface footage, chip load, and required horsepower, determined by what you are cutting and what you are cutting it with, (who uses H.S.S. anymore?) were determined long before any of us started making parts. It is in the Machineries handbook.
I have a little piece of software that is freeware that is pretty good for giving you a starting place for F & S on mills and Lathe's called SPEEDZ. Send me a note and i'll email you a copy. Its well worth the price ( Free) -Chris-
Hi Chris. I would love to try out that software that you're refering to.
Chris,
I too would like a copy of this SPEEDZ freeware as I was looking for something like it. I sent a PM with my email details.
Thanks in advance,
Grumple
Post a link to the chart for milling!
I got the SPEEDZ application from the link below. The first time I tried the page was not found. Its working at the moment so get it while you can.
http://iwr.ru.ac.za/~iwdf/lathe/speedz.zip
Regards,
Grumple
