588,638 active members*
5,549 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Need help with cv/ccw - dir/step conversion
    Nov 2005
    19
    Hello to all,
    I have an old Vexta stepper driver with negative ground and CW/CCW inputs. Most of the breakout boards have only STEP/DIR outputs and I will be very happy if somebody post the circuit diagram for this conversion. Thanks in advance.
    Jan 2010
    2141
    You may want to look at this thread:
    http://www.cnczone.com/forums/genera...ir_cw_ccw.html
    Nov 2005
    19
    Thank you, that's exactly what i am looking for.
  1. X3 CNC Conversion- the new red-headed-step-child
    By WOTDesigns in forum X3/SX3/G0619/G0463
    Last Post: 02-10-2015, 08:49 AM
  2. G0602 10x22 LATHE 3 STEP CNC CONVERSION
    By Crevice Reamer in forum Vertical Mill, Lathe Project Log
    Last Post: 03-09-2012, 11:20 PM
  3. Step/Direction pins should be Step FWD and Step BACK
    By rayscott in forum Mach Software (ArtSoft software)
    Last Post: 02-10-2010, 12:57 AM
  4. Stepper motor step/Direction conversion.
    By shujah in forum Bridgeport / Hardinge Mills
    Last Post: 10-15-2009, 01:49 PM
  5. 4 phase input to Step/Dir conversion?
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 02-11-2007, 05:40 AM
