Originally Posted by
MrWild
Again, the rails are unsupported. Vibration ruins cuts and cutters. Once a cutter starts degrading due to chipping from vibration, it gets worse fast. What kind of aluminum are you cutting? How big a cutting area do you need? Oy, I just looked at the motors. An even firmer NO WAY. Many machines clam CNC capable, but the axis motors and drives are only good for light duty. Notice the note by the motor stating (used). Usd motors of puny size with weak drives that ham string you into not being able to upgrade without major extra expenses make these machines poor choices. While aluminum is easier to cut than steel, it is a LOT harder to cut than wood and plastic. The pictures show it cuts plastic, wood, and .002 thick copper on PC boards.
I realize you are on a budget, but going cheap with something that appears like a good deal will ruin a business fast when it fails you.
