Hello everyone,
Some customer ask about how to set lubrication system on the machine. You can see there are 3 buttons on the lubrication system, you can add the engine oil into it once it is alarms and shows error on it. When you first switch on the machine, it will works for one time.
Press set button for about 3sec, it will show you a time value for minutes, this means how long of the interval it will lubricate the blocks, you can press up and down to set the time, then press set button again to save it. Then you can press set button again for about 3sec, it will show you another time value for seconds, this means how many seconds it will works for one time, also you can press up and down to set the time and then press set button to save it. After the end, it will works for one time and then the minutes will countdown.
Here are 2 pictures for your referemce, you can adjust the screws to set the amount of the oil for xyz axis.
Best regards,
Fanny from Roctech
