I have a 7x10 HF lathe that I am learning to use. It actually works pretty good for threading thin rifle barrels and making thread protectors etc.
The problem I am having is after stalling it when I taking too big of a bite. I am having a hard time figuring out how the overload protection works. If I stall it, I can't seem to figure out how to restart it. It seems like only luck with various switch combinations will get it started up again. I've followed the instruction manual but they never work after a stall.
Do you need to unplug the machine for X minutes or are you supposed to stand on your left foot and count to 10? What is the trick to getting them to come back on after you stall it? Plugged in, I've had the machine refuse to start back up the next morning.
Here is the start up process that the manual says to follow (it does not work after a stall though).
1) Turn on the power switch
2) Set direction indicator
3) Turn on the speed control knob
The manual and customer support were no help.
Thanks for your help. I tried to search this forum for an answer but was not able to find the answer.
