Hei folks...
I have a' servodrive from panasonic minas s-series and i ned the com cabel ise it posebil to make it on mey oven and if yes does enyove have the conections....
best kim jessen
Hei folks...
best kim jessen
I had the same problem. since the RS232 connection uses the
3 pins across the center of the DIN connector, I just used
3 pieces of solid wire (cut off of some resistors). I pushed
the wires thru a piece of thin cardboard and them put some
epoxy on top of the paper. The din connector has 8 pins.
Row of 3 on top, row of 3 in middle and row of 2 on bottom.
The middle row are pins 5,4,3 looking at the drive. From left to right.
5 txd, 6 signal ground, 7 receive.
