588,687 active members*
5,693 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > machining trouble
    Jan 2004
    39
    Unhappy machining trouble
    Hello, everyone, I am trying to machine a pocket which is a round hole in the middle in my part, the trouble is that the size comes out 2mm smaller then drawn, unless I draw the hole oversized in my cad program.
    Does anyone have any idea why this is happening, or have been through anything similiar?
    /Anders
    24222
    Tool offset correct?
    Maybe if you post the program with the tool dia you are using it might help.
    Al.
    Albert E.
    Jan 2004
    39
    the tool offset should be correct, it's just a matter of setting up the correct tool size in the create/select tool dialog isnt it?
    Mar 2004
    1543
    Any time I got a problem like this I start beaking it into smaller pieces.
    I'd put a felt tip pen in the spindle and a piece of paper for my part. Then run a manually G code program to draw a circle: (NOTE: your version control probably doesn't Gcode exactly like my control)
    G00 X0 Y0
    Z -1.0
    G01 X1 F10
    G02 X1 Y0 I0 J0
    G00 Z0
    X0 Y0
    Then I'd set up T1 for a 1/2 inch cutter and insert the command T1 G41 after the Z -1 line. See if it offsets as you expect. If so, the problem is in the cam package.
    Karl
    Jan 2004
    39
    I'll try it after 16:00 today, Thanks for the help
  1. Machining rubber
    By HuFlungDung in forum DNC Problems and Solutions
    Last Post: 05-01-2011, 09:59 PM
  2. High Performance Machining or HSM
    By Scott_bob in forum Polls
    Last Post: 04-27-2006, 08:34 PM
  3. Machining 2219-t4 aluminum
    By scottwally in forum MetalWork Discussion
    Last Post: 06-19-2005, 04:53 AM
  4. Reintegrating machining in our company
    By beast in forum MetalWork Discussion
    Last Post: 03-24-2005, 02:51 PM
  5. aluminium and steel machining
    By Hobbiest in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2004, 04:59 AM
