588,172 active members*
4,391 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Control Technology Corp. Servo drives
    Nov 2003
    244
    I purchased the CT model 2329 servo drive on Ebay and was wondering if anybody is familiar with how these units work? I know that they use a +10 and -10 volt for direction control but that is all I am able to find out about them. There is only command and enable inputs on them. how can I use these with feedback? If I am unable to use them with a cnc router then at least I have a good power supply as they have a dual coil 24v toroid transformer in them with rectifier and cap. series output is 77v so I guess that parallel would be around 38v. Any suggestions?
    Tom
    Nov 2003
    244
    Finally found out that they require an adapter card for positional analog feedback, guess I have my power supplies for my gecko's.
    Found out Rutex has a step direction driver for these .
  1. What servo drives use resolver inputs?
    By murphy625 in forum Servo Motors / Drives
    Last Post: 03-15-2005, 07:28 PM
  2. Servo control software
    By gareth in forum Servo Motors / Drives
    Last Post: 02-05-2005, 02:17 AM
  3. Need input for servo control systems
    By cncadmin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-31-2005, 05:45 PM
  4. steppers or servo drives
    By mmjpotter in forum Gecko Drives
    Last Post: 03-30-2004, 09:56 PM
  5. Some Servo Control Questions
    By Noah in forum CNC Machine Related Electronics
    Last Post: 03-02-2004, 05:41 AM
