Originally Posted by
jueston
when you loosen the spring that holds the rack against the pinion with the power off, can you easily spin the stepper and rack gear? when i built my PRO4848 i over tightened several parts, and this was one of them. if you can't easily turn the stepper and rack gear reduce the tension a little and reinstall.
i also over tightened the eccentric bearings on the risers, and all of these things being to tight each added friction to the movements which caused my X-axis to loose steps.
