588,053 active members*
4,198 visitors online*
    Oct 2012
    13
    gcode problem with mach3 (jogging works fine)
    I have strange problem.
    when I use jogging in mach3 everythings fine (all axis work fine) cnc responds correctly all motors move. when I load gcode (even with ONLY G0 commands) motors movel VERY VERY slowly and incorrectly. in mach3 it shows me axis have moved with 40 in realuty 1. when I turn jogging everythings fine. can anyone help?
    Jan 2010
    2141
    Is it possible that your acceleration settings are too aggressive and so the motors are losing steps or stalling?
    Oct 2012
    13
    Thank you for response but if so then my cnc wont work properly on jogging , but it does. everythngs ok when koggin.g problem starts when I run gcode.
    Aug 2007
    298
    Re: gcode problem with mach3 (jogging works fine)
    did you get this working? I'm having same issue
  1. fuji fsd80 drive works fine in manual but not in MEM or MDI
    By jolulank in forum Servo Motors / Drives
    Last Post: 02-25-2014, 03:48 AM
  2. Replies: 1
    Last Post: 10-28-2013, 06:51 PM
  3. Need help getting parport to work, works fine under linux.
    By CptanPanic in forum Mach Software (ArtSoft software)
    Last Post: 07-29-2012, 02:59 PM
  4. Problems with Mach3 Jogging.
    By Ncrazyballa in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2012, 01:27 AM
  5. solid works to gcode
    By bradeyk in forum Solidworks
    Last Post: 08-15-2011, 08:58 PM
