588,444 active members*
5,116 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need info on A860 pulse-coder (encoder)
Results 1 to 8 of 8
    Mar 2004
    369
    Al the Man helped me out before with some VERY useful Fanuc documents on the early Fanuc red cap motors/encoders and helped me to come up with an encoder converter. I just had a guy call me, he has a 2002 Fanuc control with A860-2020-T301 encoders on A06B-0078-B003 and A06B-0085-B103 motors. I don't have any documents for this series of motor/encoder, so I don't know if my commutation converter will work on it or not. Does anybody have any info on these encoders?
    Thanks in advance for any light you can shed on this!
    Jon
    24221
    You may be in luck, the old designation was Bx03 which if it has a 17p MS connector, is 3000p incremental, instead of 19p MS, if 19p then it is absolute.
    the x is 1 for taper shaft or 0 for straight shaft.
    Al.
    Albert E.
    24221
    What is the Fanuc cnc controller model?
    Al.
    Albert E.
    Mar 2004
    369
    Al.
    The guy who called me was rattling off a bunch of stuff, but I think he said 15T. I could have that wrong, however.
    Do you have documents like those pdf scans with a long listing of motors and encoders that you have provided to a couple people before? A quick scan of those did not turn up numbers matching either the motor or encoder. Yes, the B003 and B103 ending on the motor numbers did look like they might indicate these follow the same standard. What we are trying to figure out is if the converter I made for the A06B-0315 and similar motors with the B1 B2 B4 B8 commutation signals will work with his motors.
    Thanks much!
    Jon
    24221
    Jon, I actually took the integration course for the 15 and have all the manuals in hard copy, possibly a way to get the info is if you can confirm it is a 15T and find out the board number the encoder is plugged into and the Honda plug input to the board, e.g. Base2 board (01P24) and Honda plug CF21.
    The absolute encoder is actually the same as the differential, just that it has battery backup, the other type fitted could be a serial encoder, where the encoder is plugged into would tell.
    Al.
    Albert E.
    Mar 2004
    369
    Al.
    I did a bunch of poking around on the GE/Fanuc site today and may have figured out a little bit on these motors. They are from Fanuc's Bis series (These B's are really the Beta character), specifically the B12/3000is and the B22/2000is. The encoders are called a B128ia, 131072 counts/rev, and it looks like they have a serial output. So, I may need to develop a new converter for these. Do you have any info on the format of the Fanuc serial encoder signals?
    Jon
    24221
    Quote Originally Posted by jmelson View Post
    Jon
    I have the pin out only for the transmit/receive channels, but don't have anything on the format of the signal yet.
    Al.
    Albert E.
    Mar 2004
    369
    J is if you can confirm it is a 15T and find out the board number the encoder is plugged into
    Al.
    OK, I totally mis-remembered what he said. The control is an OI Mate MB (is that the same as an OI-MB?)
    I don't know anything about that control. I'm trying to get info on the connectors on the encoder.
    But, the guy says he can loan me a motor to try to figure out the scheme.
    Jon
  1. pin out pulse coder A860-0360-v501
    By Montabelli in forum Fanuc
    Last Post: 03-18-2024, 05:02 PM
  2. Pulse coder alarm
    By stevo1 in forum Fanuc
    Last Post: 08-18-2010, 07:18 PM
  3. Serial pulse coder
    By bigalow in forum Fanuc
    Last Post: 02-19-2009, 04:28 PM
  4. Unfit Pulse Of Pulse Coder Alarm
    By Crashmaster in forum DNC Problems and Solutions
    Last Post: 04-23-2007, 03:55 PM
  5. Fanuc Pulse Coder
    By Derek.C in forum Fanuc
    Last Post: 01-04-2007, 03:24 AM
