587,349 active members*
3,601 visitors online*
Results 1 to 13 of 13
    Dec 2005
    600
    Power supply effects
    Couple of quick questions on power supplies - if I increase the voltage, what effect does this have on the stepper, and if I increase the amperage, what effect does this have on the stepper?
    Mark
    Mar 2010
    Hi Mark,
    From my readings:
    - Increasing voltage, decreases step time as the inductance of the motor is able to be overcome more quickly. Result is it can step faster
    - Increasing current, increases the holding torque of the shaft.
    With increased current comes more heat and risk of coil burnout so increase current with caution.
    Hope this helps.
    Regards,
    tdpomodoro
    Dec 2005
    600
    Thanks. More voltage is definitely a good thing then, to a point? Since it moves the stepper faster, does it give the stepper more turning power (or torque)?
    My reason for asking this, I've got a relatively heavy Z axis on my gantry machine. In order to keep from stalling or losing steps, I have to run the stepper slower than I'd originally intended to. I wanted to try a higher voltage transformer to see if I could help the Z axis out a bit, since the higher voltage transformer is a relatively inexpensive upgrade.
    Mark
    Aug 2005
    191
    I run my power supply at 20 times the voltage on the stepper nameplate which is what has been recommended by various articles as a reasonable max figure to use. The steppers seem to work great at this voltage.
    Make sure the new voltage does not exceed the maximum voltage spec of the control board. Also keep in mind that the ac voltage level off the transformer will change after it goes through the rectifier.
    Jan 2007
    146
    DC voltage will be about 1.4 times the AC voltage.
    Another max voltage formula for stepper motors is 32 times the square root of the motor's inductance according to Maris of Gecko drives.
    As cautioned check your stepper drives max voltage.
    Jun 2009
    35
    A picture is worth a thousand words...
Name:	stepper performance.jpg
    Matt Adams - Motion Control Application Engineer
    IMAC Motion Control - Elgin, IL
    Dec 2005
    600
    Matt,
    Perfect! That's exactly what I was looking for. I'm somewhat limited to 40 VDC by the drivers (Keling 4030's). The power supply that came with the kit is a 24 volt 8.3A (KL-201-24) and I was thinking up upping that to the KL-350-36, a 36 VDC 9.7A power supply. The steppers have a 4.17V rating in bipolar, so I was hoping to give it a bit of a boost.
    mark
    Oct 2005
    2392
    Just be aware that you will get increased resonance and vibration with higher motor voltages when the motors are moving slowly!
    I recently "upgraded" my PSU from 25v to 40.5v and I'm getting some significant vibrations, and on cutting hard materials a worse surface finish, and on cutting soft materials it is more likely to gum and melt. A lot of people here seem to be gung-ho about getting super rapids speeds, but for me it's not worth sacrificing significant cutting performance just to get 20% faster rapids on the rare times I want faster rapids.
    I'm just about to mod my new power supply to drop it back to about 33v for testing. Hopefully that will be a nice medium.
    Mar 2004
    576
    Be careful about back-EMF too though. The stepper-motor coils are inductors, and will generate a voltage back into the drivers (called "Back-EMF"). You can notice this if you connect a voltmeter to any coil of a stepper motor (not connected to anything else) and rotating the stepper shaft. When added to the power-supply voltage, this total must not exceed the driver voltage rating (though there are exceptions to this rule). Calculating how much back-EMF will be generated is somewhat of a black art, and depends on the specific motors, the speeds you're running it at, and whether or not it's a full moon.
    The exception I mentioned is that some drivers will claim a voltage spec, but can handle a temporary higher voltage for those back-EMFs. IIRC Gecko's do this. You can also add a small circuit to shunt the back-EMF and prevent it from going into the drivers.
    EDIT: Found the shunt circuit...
    http://pminmo.com/PMinMOwiki/index.p...le=Power_shunt
    FWIW, I got my CNC mill used with very nice IM805 drives but a crappy 24V switching PS. I upped that to a 68V linear PS and pick up loads of performance.
    Cheers,
    -Neil.
    Mar 2004
    576
    RomanLini -- have you considered a vibration damper, such as this... http://www.cnczone.com/forums/showthread.php?t=32284
    Oct 2005
    2392
    Thanks for the suggestion. I've already got vibration damping linear bearings and vibration damping leadnuts.
    I was just making a point that going from a 25v PSU to a 40v PSU gave significantly worse performance. If high rapids speed is the only type of performance you are concerned with then by all means bump your PSU volts right up there...
    Dec 2005
    600
    I like the vibration dampener solution that uses hockey pucks...
    mark
    1695
    The puck idea is nice and simple, but it might stop working relatively quickly as the hole rubs away and enlarges over time.
  1. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  2. power supply
    By johnecy in forum CNC Machine Related Electronics
    Last Post: 05-23-2008, 03:11 AM
  3. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  4. Power Supply
    By KrashKing405 in forum DIY CNC Router Table Machines
    Last Post: 06-08-2006, 01:33 AM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
