603,963 active members*
3,212 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Tooth profile for designing synchronous drive sprocket?
Page 1 of 2 12
Results 1 to 20 of 24
    Mar 2010
    I cross posted this in OpenSource Software forum , but applies equally here. I need a CAD program solely for designing 2 sprockets. The problem is finding one which has tooth profiles, specifically, Gates Poly Chain in 8mm pitch. I'd rather not spend $900 for software just to design 2 sprockets. I've search here, and Googled elsewhere with no firm candidates. Any suggestions/guidance would be greatly appreciated.
    Mar 2006
    2712
    There are dimensions available in the Gates on line catalogs and engineering pdf's.
    Dick Z
    DZASTR
    Dec 2008
    4545
    You can go here and configure your specs and download a model for it:
    http://www.gates.com/designview/inde...ocation_id=866
    Mar 2010
    Thanks guys. Been there, and when clicking through the "Partview" feature for both specs & cad files, I stumbled across this:
    Not all samples displayed the above, but both the 30 and 71 grove (among others) in the 8mm pitch x 12mm width, did. Needless to say, because of the critical nature of the profile, I'm a little dubious because of the warnings.
    Dec 2008
    4545
    Never downloaded a model to see that pop up. It would certainly be a deal breaker!
    Maybe call that number in the disclaimer and see if they have a solution to offer for designing these.
    May 2008
    266
    This DXF is a 5mm pitch pulley straight out of CamBam after being scaled by 1.6 to get the 8mm pitch you're looking for. Is that any good?
    Picture is of the same DXF after extrusion in ViaCAD.
    Martin.
    Attached Files Attached Files
    Mar 2010
    blowlamp,
    Sprocket grove profiles are critical and must match the belt designed for it. Grove pitch is only one of the criteria. See examples below.
    Your example looks much like this:
    The Poly Chain profile I'm seeking, I believe, looks much like this one:
    Dec 2008
    4545
    Here's a step file of a gear I downloaded from that site, just for giggles.
    It was this one: 8MX-30S-12
    I included the 2d spec sheet they publis, and all the numbers seem to jive. COuld the disclaimer be just a protection scheme? How can they publish stuff as "the engineering specs and data, and say it's not a true representation?
    Maybe they just want to sell them to you instead of have you make your own.
    This model matches the data.
    Maybe someone experienced in this area can comment on the model.
    Surely you will want to confirm things before destrying some machine though...
    Mar 2010
    Attached is what I suspect is the original patent for the Gates GT (Poly Chain) profile:
    Mar 2010
    Quote Originally Posted by BurrMan View Post
    Absolutely. The belts arn't exactly expendable either. I bought two @ $50 each... wholesale.
    May 2008
    266
    Oh, I see now.
    It does beg a few questions and observations though. My first being:
    1/ Why is the standard form not suitable?
    2/ Is the CAD drawing just a representation or is it to be used for manufacture?
    3/ If the design is patented, would it be legal to make your own anyway if done commercially?
    If you intend to make this profile, I think it might be quite an involved process even if you can draw the proper tooth form.
    In your second drawing there are a couple of corners (that look important) in the root of the tooth, that can't be taken out cleanly by normal endmilling because of the cutting tool radius. That probably leaves form tools or possibly laser cutting, although I'm not sure how suitable a laser-cut surface would be for running a belt on.
    Martin.
    Mar 2006
    2712
    Thanks MVHPV, The patent drawings supply many answers. Looking at the date of the patent raises a question; Is this the CURRENT form?
    Gates' latest form, GT 2 has a form similar to a gear, an involute on the sides of the groove.
    One other thing, if you can buy the sprockets, why go through all the effort to draw and make your own? Just curious.LOL
    Dick Z
    DZASTR
    Mar 2010
    Quote Originally Posted by blowlamp View Post
    Among the many dozens I've seen, what is a 'standard' profile?
    Not sure what you mean. While Gates seems to offer the exterior dimensions in CAD drawings, I'm not convinced the drawings accurately represent the profile. But I could easily be mistaken.
    Cutting one or two prototypes for an experimental project wouldn't likely be an issue. But I certainly wouldn't mass produce any or try to market any.
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dunno. That's the reason for seeking a CAD program which may have the profile included in it's library.
    Therein lays the problem, Gates doesn't make the sprocket I need - specifically, the mounting is completely different, and I'd prefer 7075 aluminum. Yes, Gates offers "made to order" customs, but I'm guessing the costs would be beyond my budget. I also have access to local CNC should I need different ratios (a strong possibility).
    Dec 2008
    4545
    Martin.
    The flat is a true flat, so a simple index on a rotary should cut it.
    Dec 2008
    4545
    Still looking for a sprocket expert that can confirm the model as "true" or not. If true, no need any software as the models are available. I dont know enough about them to say if it is just a "toy model".
    Anyone?
    Beuller.....Beuller??????
    May 2008
    266
    MVHPV.
    The reason I posted the file produced by CamBam is because I believe it will allow you to easily produce pulleys for use with timing belts that are commonly available.
    If the CAD drawing was only intended to represent the basic form of the pulleys I was going to suggest that you don't go to too much trouble in getting an exact shape. Conversely, if the drawing were to be sent to a CAM system for manufacture, it would need to be accurate.
    BurrMan
    That would remove some but not all of the material in that area, a little would remain on each curved section near the root.
    Martin.
    Dec 2008
    4545
    I am assuming that the sides come off of the assembly. A straight pass over the top.
    Mar 2010
    The reason I posted the file produced by CamBam is because I believe it will allow you to easily produce pulleys for use with timing belts that are commonly available..
    The Poly Chain GT is available in over 29 different belt lengths spanning 4 different widths - that equates to 116 individual sizes. Bare-in-mind, that's counting only 8mm pitch. Doesn't seem too uncommon or unpopular to me. http://www.vbeltsupply.com/8mmpolychainseries9274.html
    Also...
    The Poly chain exhibits the highest efficiency of any currently available belt drive, short of roller chain. Crap!... now i'm beginning to sound like a salesman.
    Question Blowlamp,
    Does CamBam specify manufacture's profiles, or just one or two generics?
    May 2008
    266
    Quote Originally Posted by MVHPV View Post
    Also...
    Question Blowlamp,
    Well I never did doubt that there would be a selection of available products, but the fact remains that the The Poly Chain GT tooth profile is not as common and is going to be harder to machine than the HTD tooth form because of its shape.
    I've just checked the CamBam documentation which says the pulleys are made to the HTD5 form. See here: http://www.cambam.co.uk/docs/tutorials/profile-new.html
    This might be of some help See here: http://www.roymech.co.uk/Useful_Tabl...ing_belts.html
    Martin.
    Sep 2008
    117
    Assuming you can buy an existing sprocket of the correct diameter and pitch, any competent machinist or toolmaker with an optical comparator can document the profile by sectioning the sample.
    Gene
Page 1 of 2 12
  1. Trying to find a gear tooth profile generating software.
    By Zenji in forum Mechanical Calculations/Engineering Design
    Last Post: 06-12-2014, 11:48 PM
  2. Designing profile follower using Mach3
    By marklh in forum Mach Software (ArtSoft software)
    Last Post: 04-16-2013, 01:15 PM
  3. Sprocket Profile Generation
    By big_mak in forum Mechanical Calculations/Engineering Design
    Last Post: 08-17-2010, 01:25 AM
  4. CAD Prg for creating synchronous drive sprocket?
    By MVHPV in forum OpenSource Software
    Last Post: 03-23-2010, 09:12 AM
  5. Require DXF/DWG for 35 tooth sprocket.
    By Kiwi in forum Uncategorised CAD Discussion
    Last Post: 06-16-2009, 08:56 AM
