586,094 active members*
3,709 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Need Help Finding Correct post using Mastercam 8 for fadal VMC 88HS
    Mar 2010
    20
    Apr 2003
    1876
    Have a look here first.
    Then go look in your POSTs folder in MCam, there should be a generic fadal post there that works OK. Also, a HAAS post will work, as well as a fanuc post.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Mar 2010
    20
    I have tried all of the fadal posts, none worked, The first one wanted me edit the post specificly Variable not defined full_arc_flg post line 1130 on
    mpfadal1
    Jul 2005
    205
    Quote Originally Posted by wiley125 View Post
    mpfadal1
    Are you using Format 1 or 2?
    If I am not mistaking, the post is one thing and the other is how you set up the control in MasterCam. This lets you define if arcs are broken at quadrants or doing full 180 degree sweeps and much more stuff like how tool changes are dealt with.
    If you want, pm me. I have a 4020 88HS, Master Cam, and a few Fanuc controlled VMCs.
    Andy
    Jun 2005
    305
    The generic MasterCam Fadal post is set up for format 2.
    The machine behaves differently in format 1.
    I always ran my Fadals in format 2.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
  1. Fadal 4020 88HS IMPORT / EXPORT
    By cam280 in forum Fadal
    Last Post: 06-30-2009, 03:14 PM
  2. Replies: 5
    Last Post: 10-19-2007, 02:42 PM
  3. Fadal 88HS Comunication errors
    By TR MFG in forum Fadal
    Last Post: 10-09-2007, 01:08 AM
  4. Fadal 88HS problem
    By rai in forum Fadal
    Last Post: 09-01-2007, 04:36 PM
  5. Fadal CNC 88HS Post Processor Required
    By cncsydney in forum Uncategorised CAM Discussion
    Last Post: 12-04-2006, 07:07 PM
