603,355 active members*
3,774 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > ArtCam Feature????
Results 1 to 9 of 9
    Oct 2004
    40
    ArtCam Feature????
    I've never used ArtCam Pro, but a freind of mine purchased it for his shop. He wasn't able to answer my question so I'll ask the guru's of this site.
    If I use ArtCam to create a mold, and i tell it the dimensions of my block of material. And after I create the file i want to machine into a mold. Can ArtCam tell me how much void or material i've removed. Allowing me know exactly how much material a vender will use to fill this mold?
    I've worked all the bugs out of this adventure except the exact amount of material of the void. I guess i could machine one, and then pour water into the mold and calculate that. But I thought that Artcam might have that feature or information.
    And if ArtCam doesn't have this feature to figure this out. Is there any other software out that that does?
    Don
    Nov 2003
    16
    There is a volume function. I have seen it used in the training video. I think it is under the "relief" tab. I can confirm that later.
    Oct 2004
    40
    Thanks justin,
    I'll have to head down the road afterwork tomorrow and check that out
    Don
    Oct 2004
    40
    I wonder if thats the amount removed or the amount that is left after machined?
    Don
    Nov 2003
    16
    if I understand it right, you can select the relief that you wish to know the volume of. There is also a lot of help with that stuff on the ARTCAM forum site.
    Sep 2003
    111
    Volume calculations in VS3D
    VS3D can report the volume of a sculpted relief surface (mold).
    And it can do it from the original surface, or after the machining passes. So you can see how much material the mold holds, as well as how much material remains to be cut. The "Help / Surface Statistics..." menu in VS3D is where the volume report can be generated.
    Daniel Carr - President,
    Designs Computed, LLC
    Aug 2004
    3215
    i have seen it in a g-code from someone do a circle by toolpath on inside it make a long g-code, instead of a short line telling it from start to curve I and then end.
    Instead it moved x and y all around the curve.
    35494
    It probably has to do with the post processor converting circles into short straight segments.
    Aug 2004
    3215
    Quote Originally Posted by ger21
    maybe it was the way it exported?
  1. A new feature in Mach3....
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 09-09-2017, 08:48 AM
  2. ArtCAM substitute?
    By Arnie in forum Rhino 3D
    Last Post: 10-19-2016, 04:34 PM
  3. Plasma G-code with Artcam?
    By coherent in forum ArtCam Pro
    Last Post: 11-23-2006, 02:31 AM
  4. ArtCam with 2 routers?
    By walter in forum ArtCam Pro
    Last Post: 06-26-2004, 10:10 PM
  5. Software that is compareablr to ArtCAM
    By matt in forum ArtCam Pro
    Last Post: 06-07-2004, 03:04 AM
