588,306 active members*
5,012 visitors online*
    Feb 2005
    117
    anilam glass scale incorporaton
    I have a mill equipped with anilam glass scales on all three axis. I want to incorporate this into a conversion using rutex product. Supposedly these scales will work as encoder inputs. Anybody done anything like this? Thank you.
    24220
    I have done it with Heidenhain scales. If you have, or can get the pinout they hook up the way a normal encoder does, a minimum is usually A ch, B ch, +5 and Common.
    Al.
    Albert E.
  1. milling glass
    By corpse in forum Glass, Plastic and Stone
    Last Post: 08-01-2007, 02:47 AM
  2. RS-232 / Dnc, Pc To Anilam Crusader 2 Anybody Doing It?
    By jpb6061 in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2007, 12:12 PM
  3. Encoder Mounting Position?
    By Willyb in forum Uncategorised MetalWorking Machines
    Last Post: 12-17-2004, 05:51 PM
  4. Spindle choice - Glass CNC
    By digital in forum DNC Problems and Solutions
    Last Post: 10-30-2004, 05:37 AM
  5. Very Basic Scale DXF Question
    By awm in forum BobCad-Cam
    Last Post: 01-07-2004, 05:11 PM
