603,834 active members*
2,694 visitors online*
Hybrid View
    Oct 2005
    332
    Fanuc Ladder III PMC->PC
    ******* solved from this up to ....
    Trying to receive the ladder from the PMC (21-TB), before trying to send a changed version to the PMC.
    The controller starts to execute and hexadecimal running appears on the right side (seams that it is running ok), after a while the controller says completed. That is ok also. But on the PC side it keeps always "running" and does not go away from that. If I press "cancel" nothing was retrieved from the PMC.
    I have attached pictures of PC, controller at the end of transmition and controller transmitions settings.
    Thank you for comment.
    ******** this
    I have managed to send a new ladder from the PC to the PMC. Ladder was present on the controller, until I turn the controller off.
    What is necessary to make it permanent?
    Thank you.
    Attached Thumbnails Attached Thumbnails P4130002_cnczone.jpg   P4130003_cnczone.jpg   P4130005_cnczone.jpg
    Mar 2006
    167
    My understanding is that you have to write it to F-Rom in order for it to stay in the machine after reboot. Not entirely sure if this is correct for your control or your method of editing, but on i-series controls when I edit on the machine, I must write to F-rom if I wish to keep the changes.
    Oct 2005
    332
    This is also solved. Some information for anyone with the same issue.
    My control (21TB) does not let me edit the ladder on the control - or I do not know how to. I had to changed it on the PC. Using also the PC I was able to send the new ladder to the machine with RS232, and then, under "I/O ALL" changing to F-ROM / WRITE the controller "burns" the current ladder to the F-ROM, so changes were keeped!
    Thanks!
  1. fanuc-o ladder
    By Bill Clark in forum DNC Problems and Solutions
    Last Post: 09-29-2011, 07:35 PM
  2. fanuc om-a ladder
    By rathi_vk in forum Fanuc
    Last Post: 06-12-2009, 03:34 AM
  3. ladder fanuc om-a
    By rathi_vk in forum DNC Problems and Solutions
    Last Post: 01-11-2009, 08:34 PM
  4. FANUC LADDER
    By CHAD LAWSON in forum Fanuc
    Last Post: 12-08-2008, 07:47 PM
  5. Fanuc ladder
    By guhl in forum Fanuc
    Last Post: 12-07-2007, 07:54 PM
