588,513 active members*
4,725 visitors online*
    Jul 2007
    38
    Wasino lathe ball screw
    I've got a late 90's Wasino LG-7 and am noticing the X axis is very sloppy. I know you can adjust for backlash in the CNC parameters but this seems really bad. Other that replacing the ball screw is there any way to tighten this to remove some of the end play?
    Rich
    Mar 2006
    2712
    Is it possible the end play is in the support bearing assembly (bearing slop, brackets holding the bearing, attachment points of the bearing housing)?
    Dick Z
    DZASTR
    Jul 2007
    38
    Yes I suppose it could be that. I just noticed a lot of movement in that axis and was looking for some ideas on what I should be looking for
  1. 9 X 20 Lathe Z travel Ball Screw
    By Me2 in forum Mini Lathe
    Last Post: 05-24-2009, 11:34 AM
  2. Wasino gang tool lathe W/3T control
    By kz1670 in forum Fanuc
    Last Post: 10-17-2008, 05:06 AM
  3. lathe turning a ball screw end
    By margni74 in forum MetalWork Discussion
    Last Post: 12-05-2007, 04:57 AM
  4. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  5. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
