603,400 active members*
2,394 visitors online*
Page 1 of 3 123
Results 1 to 20 of 48
    Mar 2004
    1306
    My homebuilt spindles
    Once you play around with this stuff for a while, soon or later many of us get an unhealthy interest in making our own spindles.
    Presently I am working on making two different spindles so I thought I'd share them.
    The ER-32 collet spindle is being built into the housing of an industrial right angle reduction gearbox I picked up from the scrap dealers. It will replace the ER-16 Sherline industrial spindle I currently have on my FrankenDeckel.
    The Other one is a small Proxxon Collet spindle which I want to use as a tool post drill, mill and grinder for the CNC'd 7x12.
    Attached Files Attached Files
    Regards,
    Mark
    Jan 2010
    485
    Nice drawings. The ER32 spindle with the tapered roller bearings, interesting the way the bearings are used. Usually the cup is mounted in the housing not in the retaining cover. Can't remember ever seeing them mounted this way. How are you retaining bearings to shaft?
    cary
    Mar 2004
    1306
    I have a Proxxon IB/E, but it is not rigid enough to use as a tool post bore grinder, as it only has a single bearing. I picked up a box full of FAG 7200 AC's off Ebay, so I decided to design a rigid spindle around them.
    Hi Cary,
    The cups are a located radially in the housing, but axially by the caps. Bearing preload has been set by shimming the cups. This was the way the angle gearbox was, and I figured a nicely aged cast iron block with precision bore is a better housing than something I'd hack together.
    I need to post some pictures of the physical parts. The picture shows the current physical condition.
    I have not decided on the bearing/ pulley retention system for the rotor yet.
    Since there is a shoulder at the bottom of and shaft and a spacer between the two inner races, the the whole rotor will be retained from the top. Whether to turn a thread and use collar nut, or use a taper locking set up which includes the drive pulley is open.
    This bigger spindle is on hold because I am more interested in the little one at present. My projects tend to take a rather meandering journey to completion.
    I need to go see a friend and get a valve spring so I can finalise that design. The spring will preload the upper, floating bearing. The design is based on Herbertkabi's recommendations here.
    http://www.cnczone.com/forums/showth...t=12184&page=5
    So far I have just made the main spindle shaft (2x - the first one I messed up), and the bearing spacer.
    Regards,
    Mark
    Aug 2008
    74
    Would you mind sharing the dimensions and angle of the proxxon taper? I've been able to locate information about the dremel taper, but I'd prefer to re-use some of the proxxon stuff I already own. I've not yet been able to find out anything official though.
    Jul 2005
    302
    Quote Originally Posted by RotarySMP View Post
    Hi Cary,
    Seems my recommendation was bit unclear - I can not understand how you thought your upper bearing will be preloaded by spring when this upper bearing is stoped with upper cup-nut? With looseing this cup-nut?
    At that - you do not use sliding cup for upper bearing - I think that height of bearing is too small to be as the part of slide. Please remember, in my desing this bearing is inside slider-cup, all bearings are (super precision) angular contact bearings, all parts made as *precision*.
    This actual Spindle has been in full work more that one year, near every day, at least 12 hours in day, sometimes even 24h. Month ago I did open ot once - to look how bearings ... everything was OK, just added bit grease and go on.
    Although this Spindle runs up to 50.000 RPM, I do not use higher than 35k, even than 1/16 endmill bits, most of all between 12 ... 24 k when 6mm ... 3mm endmills. I have 8mm collets for ER11 but not tried yet.
    Heli governor mode of new esc´s keeps choiced RPM well (some types have narrow keeping area, some has wider, like Schulze Fut.).
    My spindle has 1.5kw slotless motor made myself, water cooled - milling coolant goes through spindle. Ampermeter pulsates at 3 to 10 when small bits and at 10 to 15, even up to 20A when 6mm endmills.
    Wow-wow-wow ...-> kind of voice when governor keeping needed RPM under load and this noise level is low, comes most of all from mill and material, not from spindle.
    cheers,
    herbert
    Mar 2004
    1306
    The Proxxon Collets are 60° taper. I also looked everywher to confirm this, but ended up taking a hi res digital photo, and importing as a background in AutoCAD, then drawing lines along the taper and shaft and letting AutoCAD measure the angle. Kind of a cheap optical comparator.
    I turned mine with a 7mm larger diameter. 7.5mm would probably be better. The thread is M8x0.75.
    Regards,
    Mark
    Mar 2004
    1306
    Herbert,
    That is not the final design, as I have not yet sourced the spring. Once I have it there are a few dimensions I will need to adjust. The clearance between the upper cap and the bearing outer race being one.
    Edit:
    Actually, I just checked, and there is already clearance in that drawing I uploaded in the first post.
    Regards,
    Mark
    May 2005
    925
    how do you cool this spindle? water? air?
    forgot to ask, whats the estimated max speed of this spindle?
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Mar 2004
    1306
    I am not planning to turn it faster than 20K (more likely to gear it down to max 12K). If it gets hot I will have stuffed up the bearing preloads.
    Regards,
    Mark
    Aug 2008
    74
    Interesting approach. I guess it could be verified with a bit of spotting compound to check collet engagement with a new taper in some scrap. If my lathe wasn't in such a sorry state I'd give it a go myself ;-)
    Mar 2004
    1306
    Here are the first couple of parts made for the little spindle. The spare is simple 13mm OD 10 ID tube, 63mm long (Came out 63.02mm as best as I can measure it).
    I used 5bears method of sneaking up on the bearing journals.
    http://www.5bears.com/cnc16.htm
    Regards,
    Mark
    Jul 2005
    302
    Why to cool the spindle? Mine runs up to 50k, no needs for cooling - only motor is what wants to go hot becayse eddy, iron and copper losses. Eddy´s come highly up especially when higher speeds - it really looks like heats more than spent electricity :idea:
    My low rpm motors up tp 12k do not need any cooling except what exist through mechanical parts.
    When just spindle goes hot then something has been done wrong ... bad /wrong/ bearings... or too much preload ... too tight seal... to much filled grease ... even too much oil when oil used ... when good seals and you fill high speed spindle full of even thinnest oil then on high speed temperature rises up to ... oh dear - do not try!
    Right made spindle can come "hot" but only just like 30 ...40 degrees and Z-axis throug spindle holder is more than good enough cooling device.
    cheers,
    herbert
    Mar 2004
    1306
    Deleted
    Regards,
    Mark
    Mar 2004
    1306
    This spindle would not meet Herberts design standards, but the guy seems very happy with it.
    http://www.metallmodellbau.de/Eigenb...salspindel.php
    That was a good inspiration for me to have a go at making a less sophisticated spindle. While it won't be a perfect 1.5kW 50,000 rpm device whic will run for a year non-stop, I am confident I can make a spindle to performed better than the Proxxon IB/E mounted to the lathes tool post.
    I got two of these 200W Johnson motors off ebay for a total of 3€. I'll use one of these to get started. The PSU is a 300W ATX hack, which cost me about €10 all up.
    I am hoping to learn enough off this one to make a better job when I tackle my ER-20 spindle.
    Regards,
    Mark
    Jul 2005
    302
    mhh ... this Johnson is toy motor from past century and has not even normal bearings! For the same few Euros you can buy something like this "happy guy" used, he did Escap but some years ago I bought full box of Faulhaber 3540 coreless motors, was via eBay and bought because was very cheap and I looked only for encoders installed to every motor. These motors are well balanced and on the ball bearings exact like this Escap is.
    I dont try to vilify you, believe me, just concern ...
    Cheers,
    Herbert
    Jul 2005
    302
    Look at my Spindle works - there was action speed turned down because removed front screen and was the only way to keep camera clean,
    http://helicam.ee/cnc/CNC1.mov ,
    wow-wow-wow ... because esc heli mode keeps choiced rpm, currently reduced down to ca 15k with 4.5mm endmill,
    cheers,
    herbert
    Mar 2005
    160
    Spindle dimensions
    RotarySMP would you happen to have or know the dimensions of the guy's website you mentioned above homemade spindle dimensions?:
    I have that same escap motor (two of them as a matter of fact) and I'm interested in making a small spindle also, can you possibly help me out?
    "Are you gonna eat that?"
    Mar 2004
    1306
    Praetor,
    According to the write up, the Spindle housing OD is 33mm and 80mm long. The bearing retainers are threaded 30 x 0.7mm The spindle shaft is an ER 11 collet chuck with a 12mm OD. Their is a 2mm eccentric ring on the motor, so that the belt can be tensioned. You should be able to scale the other dimensions off those.
    Herbert,
    I liked that Video. Was it shot with a D-SLR? You use your machines for hours and days at a time. I have a young family and get out to do my hobby machining about 2x3 evenings a week. I would estimate my finished spindle will be used less than once per month for a few minutes. If the bearing and those crappy motors last 30 minutes total running time, but provide a more rigid spindle than the IB/E, I will have met my goal.
    I will make the ER-20 spindle like your ER-16, but don't want to waste good bearing and motors, until I have practiced the critical machining steps. I have been watching Ebay for Escap, Dunker and Faulhaber motors, but no great bargains have turned up lately.
    Regards,
    Mark
    Jul 2005
    302
    Praetor,
    Herbert,
    RotarySMP,
    My shop lokates beside my house on my courtyard in other building. This spindle uses ER11 shank. This gantry mill has 1000 x 380 mm useful working area on the table, means that I can set up works for all night.
    This "working area" is 10mm aluninium plate is on the strong mill table on the 8mm spacers. This alu plate has full raster of through M4 holes between every 40mm *for fixing* ... I dont know is it understandable what Im trying to tell, but this is the best mode to fix, to keep mill clean and to mill as more as possible parts in one set up. There are two pumps - one for cooling, second for cleaning. There is collector ... there is filtering system and fine filter ...
    Right now this collector is full, means that today night machine will rest.
    Was just like some new ideas for you.
    cheers,
    herbert
    Attached Thumbnails Attached Thumbnails IMG_1164.jpg   IMG_1166.jpg   IMG_1167.jpg   IMG_1168.jpg
    Mar 2005
    160
    Thanks RotarySMP, that really helps, really appreciate it.
Page 1 of 3 123
  1. My homebuilt machine
    By jbailey19 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-19-2010, 07:21 PM
  2. Hello / First homebuilt
    By big_hoovie in forum Uncategorised MetalWorking Machines
    Last Post: 05-26-2008, 07:05 PM
  3. My homebuilt cnc router is finished!
    By JMValios in forum DIY CNC Router Table Machines
    Last Post: 04-25-2006, 10:17 PM
  4. homebuilt cnc mill
    By MBG in forum Uncategorised MetalWorking Machines
    Last Post: 10-22-2005, 04:49 AM
