603,855 active members*
3,680 visitors online*
    430
    newer mach2 version, no spindle control now??
    I didn't want to continue to hijack the pendant thread, so I though I would start a new one for this.
    I uninstalled my older mach2 version, and installed a newer version. Got everything working except for spindle control.
    I have tried everything I can think of. Can anyone share how they got their spindle on/off working in the newer versions of mach2?
    (I have read the manual and no luck at all) I had this working before, man, I miss working in a shop where there was a guy you called when the computer wasn't working right!
    co
    35494
    Did you go to Configure>Ports and Pins and setup the relay activation signals under Output Signals (Use output 1,2, or 3, and have no more than 3 checked), AND setup the pins under output pins? Then, go to COnfigure>Output Devices, and make sure you uncheck the not used box, and set the spindle to the output you picked previously. That should do it.
    35494
    Are you using 6.11M? You might even want to try Mach3. I've heard it's very stable, and has a lot more features.
    430
    All set-up is correct. Spindle toggles on and off on screen, pin address is right, output 1 = CW spindle, Output 1 checked. I am stumped. And now my joystick doesn't work anymore! Sheesh
    colin
    p.s. Just checked that the spindle does indeed work when plugged into an outlet directly.
    430
    OK, figured it out.
    I turned off all the other output signals, and bing, it worked!
    cool
    thanks for all your input guys.
    Colin
  1. CNC Controlled Spindle motor speed control
    By gregmary in forum CNC Machine Related Electronics
    Last Post: 02-28-2009, 02:01 AM
  2. Spindle motor control for homebrew cncmill
    By stuart76 in forum CNC Machine Related Electronics
    Last Post: 05-21-2005, 03:10 PM
  3. How to set a relay for a spindle motor ON/OFF control
    By TTaki in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-09-2005, 01:26 PM
  4. Can Mach2 control my phase inverter
    By MrBean in forum Mach Software (ArtSoft software)
    Last Post: 10-13-2004, 01:20 AM
  5. Tutorial for Spindle Control
    By teilhardo in forum Xylotex
    Last Post: 06-23-2004, 04:43 AM
