603,344 active members*
3,443 visitors online*
    Nov 2006
    53
    Spindle IGBT Blown Out
    Hello Memebers,
    I have TNC370 with simudrive 611 analog with 6SN1123-1AA00-0DA0
    Spindle is not working and i found that IGBT on V Phase has been shorted out. I installed the other one but after two days working this again became shorted.
    Motor insulation and winding resistance are .6 ohm.
    Need kind attention in this regard.
    wahid bashir
    24260
    In many cases with IGBT drives the firing board is affected or is the original cause of the problem.
    Al.
    Albert E.
  1. fanuc spindle fuse on dc link blown
    By Nastyzen in forum Fanuc
    Last Post: 02-02-2023, 05:25 PM
  2. How to Observe IGBT QM30DY-H
    By parametric.ms in forum CNC Machine Related Electronics
    Last Post: 12-31-2009, 05:25 AM
  3. Blown F4 fuse 6T spindle
    By Jerry Shorter in forum Fanuc
    Last Post: 11-04-2009, 05:56 PM
  4. Prices on IGBT CM150DY-12
    By lester1 in forum CNC Machine Related Electronics
    Last Post: 02-17-2007, 10:11 AM
  5. Yaskawa AC Spindle Drive problems...blown?
    By nlh in forum Servo Motors / Drives
    Last Post: 08-04-2006, 01:19 PM
