586,121 active members*
3,761 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Newbie posting up my first machine thoughts - Feedback appreciated!
Page 1 of 3 123
Results 1 to 20 of 47
    Apr 2010
    Lightbulb Newbie posting up my first machine thoughts - Feedback appreciated!
    Well here are the hard parts -
    Harbor Freight 44991 (ordered should pick it up tomorrow)
    Stirling steele Belt Drive Kit for the Sieg Mini-Mill and Belt (ordered)
    Hoss COMPLETE DIY CNC Conversion Kit (ordered)
    kelinginc G540 3 axis package (One G540 + Three KL23H2100-35-4B (1/4” Dual shaft with a flat) 381 oz-in + one KL-350-48 48V/7.3A 115V /230V power supply (ordered) - updated and changed from the 387 to 381 due to Crevice Reamer's advice!
    kelinginc emergency stop button - 3 home switches - 6 feet Parallel Cable for Breakout board (on deck)
    20 ft of - Stepper-Motor-Wire-foot-2-individ-shielded-CNC (on deck)
    Software - Mach 3
    Opinions or thoughts? This is going to be a father son project. This is the son posting, If I sign my dad up with a log in he will probably post later on. Any thoughts or tips would be appreciated.
    Jul 2008
    922
    looks like you did your research. should be a great little machine with great components. be sure to post pictures of your progress!
    Apr 2010
    Quote Originally Posted by Teyber12 View Post
    That just makes me fell all the more confident :cheers:
    Will do. I plan on taking pics/posting every step of the way. I have seen a lot of build threads but it seems like everyone takes some beginning pics then gets started putting it together and forgets about it lol.
    Going to order the electronics today after I get home from work.
    Mar 2008
    3655
    Hi John. Welcome to the Zone and Congratulations!
    G540 only $250 here:
    http://retromationinc.com/retromation_015.htm
    Keling "kits" cost the same as individual parts. You can buy things separately for same prices. I would substitute the Keling 381s for 387s. It's a better match to G540:
    http://kelinginc.net/NEMA23Motor.html
    Teardown guide:
    http://crevicereamer.com/Page_7.html
    Don't forget current limit resistors and relays:
    http://crevicereamer.com/Page_11.html
    CR.
    Too many PMs. Email me to my name plus At A O L dot com.
    Mar 2008
    3655
    Just have to add something to consider:
    MicroMark is shipping the SX2:
    http://cnczone.com/forums/showthread.php?t=103714
    This would cost more, but may be higher quality, doesn't need the belt conversion kit and has more powerful motor:
    http://www.micromark.com/MICROLUX-HI...HINE,9616.html
    CR.
    387's are a very close second choice to the 381's.
    the 381's tend to be out of stock a lot so if the 387's are available,
    go for them, you won't see any appreciable difference in the 2.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Mar 2008
    3655
    Huh? I AM recommending the 381s.
    CR.
    Apr 2010
    Red face
    Quote Originally Posted by Crevice Reamer View Post
    Thanks! I didn't forget the resistors and such, your site has already been bookmarked!
    Thanks a lot for the tear down guide! That will make things that much easier!
    I already ordered the 387 kit... I just emailed them and told them I need 3 KL23H2100-35-4B motors instead. Thanks for posting that.
    Update* instead of waiting for a response I called the number in the paypal receipt and I think I woke someone up.... but she got up and changed it in the computer... so everything should be good and it should ship out tomorrow!
    Apr 2010
    This is what I got from keling inc this morning - What gives?
    Hi Sir
    KL23H284-35-4B motors will be ok
    KL23H2100-35-4B will get more speed, but motor will be hot
    John
    Feb 2010
    Welcome John! I just turn the handles, so my only thought is good luck with your project! As you have already realized, there are plenty of folks willing and capable of helping you through if you have troubles. Be sure and post some progress pics.
    Mar 2008
    3655
    Quote Originally Posted by John V View Post
    All true. Good steppers DO run hot, and there are plenty of 387s out there running with G540s. The hotter motor DOES run faster, and should still be well under max operating temp of 180 degrees.
    On an X2, the difference won't be that much, and John has a bunch of 387s to move. On a router, the difference would be significant. The 381's ARE 1/2 inch longer than the 387s, If that makes any difference.
    I just like to buy the best motor first, that's all.
    CR.
    Apr 2010
    CR.
    Well that's good to know. I confirmed this morning that they are indeed shipping the 381's. So we are good to go there.
    Also just got back from HF...
    Plan to unpack and clean this weekend, and get her ready to machine some of hoss's parts. The harder parts will most likely be done on a old Bridgeport with a DRO.
    :cheers:
    Apr 2010
    Got my base station set up in the basement today, had to start by cleaning it all up. My dad should be home tomorrow so we can move the crate off the truck and begin cleaning her up.
    I also got my belt drive package from Stirling Steele - good quality parts and fast shipping.
    I have a question regarding the electronics.. what are the relays and resistors for? I understand how they work, but not in this application.. my dad is the electrical guy and I am more the mechanical/machining guy. But having him pull up stuff on his computer while trying to explain what some of the stuff looks like over the phone hasn't worked best :banana:
    If anyone can clue me in I would appreciate it. :cheers:
    The resistors are for setting the current level on the G540 for the stepper motors, it's in the G540 manual.
    the relays are for whatever you might want to control with mach 3, flood/mist, power drawbar, addon spindle, etc.
    Hoss
    Apr 2010
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Good to know. That makes sense to me.
    I guess I am getting confused by this kelinginc - G540WD.pdf
    I'm sure once he gets home and see's it it will be easier, but right now I am stuck on the second page.
    I'm sure it'll be fine though. Thanks Hoss!
    just a note about the pdf, limit and home switches should all be wired NC in series so you
    only need to use 1 input
    Hoss
    Apr 2010
    Hoss
    I'm not that bad hoss :rolleyes
    I am more talking about inputs 5-9 and the relays
    5 and 6 are outputs
    7,8 and 9 are the spindle control output.
    pminmo has a guide for hooking up the spindle control, pay attention to your board version #
    the #'s apparently changed, hook up according to VFD GROUND, VFD OUTPUT,VFD +10VDC.
    http://pminmo.com/g540-vfd
    get the latest G540 info here
    http://www.geckodrive.com/product.aspx?c=3&i=14469
    we discussed it here.
    http://www.hossmachine.info/forum/ya...mini-mill.aspx
    Hoss
    Apr 2010
    Red face
    good links!
    Thanks!
    Unfortunately this weekends progress consisted of getting the box out of the truck, and the computer and counter area set up in the basement.
    Try for more this week..
Page 1 of 3 123
  1. Buying first Mill thoughts, Need feedback
    By Seltzer Customs in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2009, 11:28 PM
  2. New design idea - feedback appreciated
    By lsteele in forum DIY CNC Router Table Machines
    Last Post: 12-04-2008, 01:49 PM
  3. New Laser Engraver...Your thoughts and Feedback??
    By velocitygraphix in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-30-2008, 01:12 PM
  4. Any advice appreciated - newbie
    By TB300 in forum MetalWork Discussion
    Last Post: 12-27-2007, 07:19 PM
  5. newbie question - help is appreciated
    By tarsier in forum Commercial CNC Wood Routers
    Last Post: 08-03-2007, 01:08 AM
