586,108 active members*
3,256 visitors online*
    May 2007
    61
    importing and using
    ok so i finally found how to import 8020 sections but now i cant alter there length. in solidworks i would draw a line and it would just use the sectional shape. is there something im missing here?
    May 2007
    61
    I tried importing it as a 2d and 3d part.
    Oct 2005
    80
    Modifying Imported Geometry
    Imported files typically cannot be modified like from-scratch models because the source files do not contain the history of how the geometry was created; however, in your partiular case you could just use the push/pull face feature in Alibre to edit the length.
    May 2007
    61
    wow thank you very much.
    is it possible to delete the imported part and just keep the extended face?
  1. Importing Help?
    By japcas in forum Dolphin CAD/CAM
    Last Post: 07-15-2009, 06:48 PM
  2. Gsimple - Importing DXF
    By blue_steel in forum Uncategorised CAM Discussion
    Last Post: 05-09-2009, 07:21 PM
  3. importing into turbocnc
    By wantsout in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-11-2007, 02:06 AM
  4. importing .dxf
    By ToddAnderson in forum OneCNC
    Last Post: 11-11-2006, 07:34 PM
  5. Importing DXF's into V19 ???
    By tgm in forum BobCad-Cam
    Last Post: 12-09-2003, 03:41 PM
