587,066 active members*
3,532 visitors online*
Results 1 to 5 of 5
    Feb 2006
    251
    Brass Turning Video
    Made a short video today of some brass being turned on the PCNC 1100. I played with some feed speeds and got the cycle time down to a really good improvement as compared to the first time I did this.
    [nomedia="http://www.youtube.com/watch?v=EY1sWtA9LHU"]YouTube- Tormach vertical turning brass[/nomedia]
    BlueFin CNC LLC
    Southern Oregon
    Feb 2007
    156
    Quote Originally Posted by BlueFin View Post
    Very nice.... that set-up is very slick. How did you generate the G-Code?
    Feb 2006
    251
    Quote Originally Posted by kevperro View Post
    All done with Notepad, and it took a loooong time. I wish there was an easier way with CAD/CAM or something, maybe there is, but I don't know of it. But once it is setup it works great.
    BlueFin CNC LLC
    Southern Oregon
    Feb 2007
    156
    Well.... it is a nice set-up for that part. I imagine it would be easy to modify it now for other parts that are roughly the same.
    Good work.
    Feb 2007
    1041
    Nice job ! Awesome fixture too... What are they for ?
    Just a tip, if you record a LCD monitor adjust your shutter speed to compensate the interlacing (black bars).
  1. turning .003 diameter brass wire
    By camtd in forum CNC Swiss Screw Machines
    Last Post: 06-14-2008, 06:15 PM
  2. Weld Brass to Brass
    By piratesover40 in forum Welding Brazing Soldering Sealing
    Last Post: 03-04-2008, 01:02 AM
  3. Turning Brass
    By BeerFizz in forum Mini Lathe
    Last Post: 08-24-2007, 11:24 AM
  4. Turning brass
    By kdoney in forum Mechanical Calculations/Engineering Design
    Last Post: 04-30-2006, 12:48 AM
  5. -VIDEO- Turning parts with a mill
    By wisp in forum Material Machining Solutions
    Last Post: 03-15-2005, 09:26 PM
