587,246 active members*
2,817 visitors online*
    Apr 2003
    302
    Turning brass
    360 brass being turned with high speed steel insert. Positive rake and no chipbreaker. No fluid, not an option. Tried 300-1000 RPM .002-.008 depth manually and with .005-.015 feed. This thing keeps grabbing the work. The workpiece is 6 inch long 2" diameter hanging out from a 6 jaw chuck about 4" probably with <.005 TIR at the end. The lathe is too small to chuck the work closer but if the runout is the problem then I could try to turn between centers but then I'd have to drill this stuff. Any suggestions?
    Jul 2005
    12177
    No rake on brass, no chip breaker, just flat top tool.
    Cool Try using a negative rake on the tool bit.
    Brass always grabs, even when drilling! So you have to stone/grind a neutral to negative rake on the cutting edge, then it scrapes a hole in the stock!
    A Negative rake is when the cutting edge is angled above the cutting edge.
    A Neutral rake is when the cutting edge is angled lefel with the cutting edge.
    A Positive rake is when the cutting edge is angled below the cutting edge.
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
