587,645 active members*
3,170 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Need servo motor for Arrow 1000
    Nov 2006
    418
    Exclamation Need servo motor for Arrow 1000
    Anybody have a X or Y axis servo motor for an Arrow 1000 with the Vickers drives? It would be a # MT506A2-F9A1-070, and I would be interested in new or used.
    mallardfiz, do you have anything over there cross the pond?
    Best regards,
    John B.
    Oct 2008
    123
    motor
    hello i might have one ready for repair. i will make some enquiries about a good one. i dont think you will have an option for a new one only a service exchange.
    What has happened to yours?
    the Arrow 1000 has a tendancy for coolant ingress into the 'x' axis motor. it doesn't happen on the other models. if this is the case with yours then try leaving it were you can have warm air blowing on to it to try to dry it out -
    it might work.
    will be in touch.
    please send me an e-mail to [email protected] that i can respond to.
    regards
    mallardfizz
    Nov 2006
    418
    I've got the X axis one that is completely corroded away and will need replacement to be a long term fix. The Y axis motor is not nearly as bad and can be sorted, but the other is past its point of return unfortunately.
    Let me know what you find out, I'll PM you my contact info so you can send me numbers and such direct.
    Thanks for the help!
    Rgds,
    John B
    Aug 2008
    97
    It can be a gamble but we have seven Arrow 1000's, 1 750 and a 500 plus four falcons, three hawks one avenger and even an old cinturn. I started addressing replacement parts situations with our owner two years ago and he went out and bought whole spare machines for less than $10,000. This sounds like a lot but if you get even two good servo motors, spindle motor, couple of drives and atleast a few pieces of a working cpu you could save a lot of money in the long run. Plus gives you the option to repair your parts and have a spare. Right now i have three arrows and a avenger for spare parts. Oh and did not mention getting a good relay board as they seem to burn out regularly. But even with spares we are pondering trading them out for newer equipment but have found the only ones interested in them are people seeking spare parts. If you watch machine tool actions sites you may be able to pick something up for close to what siemens wants for just one good motor. But be carefull.
  1. Cincinnati Arrow 1000 Not Starting
    By zephyrmachine in forum DNC Problems and Solutions
    Last Post: 06-30-2010, 04:29 PM
  2. arrow 1000 alarm code 44-6 - need help
    By danielfdiaz in forum Cincinnati CNC
    Last Post: 09-19-2009, 03:04 AM
  3. diagrams cincinati arrow 1000
    By jaimeeduardo in forum Cincinnati CNC
    Last Post: 04-17-2009, 03:30 PM
  4. Arrow 1000 spindle trouble
    By raygun in forum Cincinnati CNC
    Last Post: 03-03-2009, 04:32 AM
  5. Acramatic 2100 Arrow 1000 need help
    By griz-shop in forum Cincinnati CNC
    Last Post: 12-06-2008, 07:49 PM
